Cargo Area Light trouble
Had to fix a few things around the house, etc. this weekend, and among other things a burnt-out highbeam, and cargo area/trunk light. The highbeam's all good, but the cargo light still doesn't work after a new bulb. Pretty sure I got the right kind - DE3021 - but with ignition on or off, lights on or off, this thing will still not work. Haven't checked fuses yet, but can't imagine it being a fuse since everything else works fine. Not a huge deal, but I can't stand when stuff is just "broken".
Searched around a bit but didn't find anything on this, ideas are welcome! Thanks!
Ok so you gota a new bulb and its not working. A bulb needs electricity to work so common sense would tell you...
The five minutes it took you to post this, if you used a little common sense yyou would've had it fixed
My trunk light doesn't work either. There is a constant +12 going to it and the negative is what is switched. I hard wired a ground but then the cluster says the hatch is open, WTF.
Thanks for the feedback guys, I'll spend a little more time on it this weekend. I also read that it can be related to the trunk latch, or the switch contacts on the light unit itself. We'll see...
ny153
Dec 27, 2006 08:38 PM
