b16a2 block with gsr crank?
Old Sep 24, 2002 | 09:42 AM
sean's Avatar
Default b16a2 block with gsr crank?
is it possible to put a gsr crank, rods and pistons in a b16a2 block therefor making it a 1.8? or do you need some kind of custom rods. ive heard some different things but i wanted to see if anyone has ever done this or know if it can be done. thanks.
Old Sep 24, 2002 | 09:49 AM
FOrSfEd's Avatar
Default Re: b16a2 block with gsr crank? (sean)
I believe this would be considered Stroking the motor and I'm not sure since the b18 block are taller becasue of the bore and stroke is bigger.
Lee
Old Sep 24, 2002 | 10:13 AM
97EXhybrid's Avatar
If you use the GSR rods I believe it will fit. The B16 has longer rods which is why the deck height is different.
Old Sep 24, 2002 | 10:56 AM
Jackson's Avatar
Default Re: b16a2 block with gsr crank? (97EXhybrid)
Wrong. The b18c blocks are 7mm taller than b16a blocks. Only way you are going to stroke a b16a using stock parts is to get a b17a crank and rods.
Old Sep 24, 2002 | 11:07 AM
sean's Avatar
Default Re: b16a2 block with gsr crank? (Jackson)
thanks, but damn. i have all these parts available to me from friends, guess i should just buy a whole new block.
Old Sep 24, 2002 | 11:30 AM
Jackson's Avatar
Try and locate a bare b18c block case. They usually go for a couple of hundred. Maybe even a b16b blockcase. Put all of the 1.8 internals in there. *B16b,B18c blocks are the same.*
[Modified by Jackson, 12:31 PM 9/24/2002]
Old Sep 24, 2002 | 11:31 AM
sean's Avatar
yep thats what i think im gonna do, thanks for all the info/help.
jdmH2Bek4
Dec 22, 2012 01:14 PM
Pinguim
32
Feb 12, 2010 02:12 PM
Skunk2R
Dec 28, 2008 04:56 PM
BukakkEK9
Mar 27, 2007 02:36 PM
weiRtech
Aug 24, 2006 11:00 AM
