Knocking issue
OK 95 ex has a knock. We checked all bearings, valve lash, torque on the camshaft and crankshaft bolts. Cannot figure out where the knocking is coming from. The funny part about it is that it only knocks when the rpm's are at about 3400 or 4500 and steady. What can the issue be. The sound is louder above engine and towards the front.
When was the last time a valve adjustment was done? Also have you checked the spark plugs for damage and/or wear?
Aftermarket header? I had a thin walled header that would make a knock/ticking noise in the mid RPM range......
Just throwing a few ideas out there...
No it happens the entire time from start up at start of day until night time when its parked.
I adjusted the valve lash yesterday to make sure and it still happened. The spark plugs are about 3 months old approx. 25oo miles on them. As for the header it is stock but I did get an aftermarket oem downpipe. I took it off about 5 mintues ago and noticed that the flange where it joins to the header, the welds look like their cracked. Could that be the cause? To test if it was cracked I turned the car on and poured water from the hose on to the header and the water just evaporated but when I poured it on the flange area steam would keep blowing.
Great this is gonna be the second time I replace this s**t. Thanks for the help though man I really appreciate it. Ill post to let you guys know if this solved the problem or not.
nycpatron
11
May 21, 2010 07:22 PM
dacrxkid4rm253
Nov 29, 2007 12:07 PM
