Knocking issue
Old Jan 15, 2011 | 08:30 PM
dansaleen_04's Avatar
Default Knocking issue
OK 95 ex has a knock. We checked all bearings, valve lash, torque on the camshaft and crankshaft bolts. Cannot figure out where the knocking is coming from. The funny part about it is that it only knocks when the rpm's are at about 3400 or 4500 and steady. What can the issue be. The sound is louder above engine and towards the front.
Old Jan 15, 2011 | 09:34 PM
92civlude's Avatar
Default Re: Knocking issue
Ive seen a few times on this engine, the block cracks between #2 and #3 cylinders, between the sleeves. This caused a knock.
Old Jan 15, 2011 | 09:39 PM
nus_dogg's Avatar
Did you check if the thrust washer rod bearing is there?
Old Jan 16, 2011 | 05:53 AM
euroraccord's Avatar
can put an audio clip so i can hear it?
Old Jan 16, 2011 | 06:39 AM
Its kind of hard to give a audio clip while I have to drive the car and you really need to have an ear outside to hear it. Sorry.
Nus dogg: What thrust rod bearing are you talking about exactly?
Old Jan 16, 2011 | 08:38 AM
thrust washer is a spacer for the crank, to reduce crank walk. so its only under load you hear it?
Old Jan 16, 2011 | 08:43 AM
yes only at certain rpm's though. Not too low and not too high.
Old Jan 16, 2011 | 09:45 AM
Is it quitter when it warms up
Old Jan 16, 2011 | 09:52 AM
GhostAccord's Avatar
When was the last time a valve adjustment was done? Also have you checked the spark plugs for damage and/or wear?
Aftermarket header? I had a thin walled header that would make a knock/ticking noise in the mid RPM range......
Just throwing a few ideas out there...
Old Jan 16, 2011 | 01:55 PM
No it happens the entire time from start up at start of day until night time when its parked.
I adjusted the valve lash yesterday to make sure and it still happened. The spark plugs are about 3 months old approx. 25oo miles on them. As for the header it is stock but I did get an aftermarket oem downpipe. I took it off about 5 mintues ago and noticed that the flange where it joins to the header, the welds look like their cracked. Could that be the cause? To test if it was cracked I turned the car on and poured water from the hose on to the header and the water just evaporated but when I poured it on the flange area steam would keep blowing.
Old Jan 16, 2011 | 02:43 PM
If you have an exhaust leak close to the manifold/header it can sound like a knock at times.
Old Jan 16, 2011 | 04:09 PM
Great this is gonna be the second time I replace this s**t. Thanks for the help though man I really appreciate it. Ill post to let you guys know if this solved the problem or not.
Stonewall551
Aug 6, 2012 02:31 PM
nycpatron
11
May 21, 2010 07:22 PM
dacrxkid4rm253
Nov 29, 2007 12:07 PM
farhan445
Nov 17, 2006 03:31 PM
hondacrxhf_3
Jun 7, 2005 06:33 PM
