Clutch Problems
Old Sep 24, 2002 | 07:46 AM
JohnysZC's Avatar
Default Clutch Problems
Hey I have a clutch problem, and this is what's going on. Sometimes the gears dont go in at all and sometimes they do, if feels realy hard to push the gear in and its only sometimes. No grinding or nothing else just the gear is very difficult to grab. I currently have an ACT OE I have had it for about a year I am turbed so im thinking with the power I have fried my clutch, now if I have should I go with CM, CForce or stick with ACT. Thanks for the help.
Note: 91 Civic Sedan ZC-Turbo DX Tranny, hope this helps.
Old Sep 24, 2002 | 08:05 AM
USDM 4G VTEC's Avatar
Default Re: Clutch Problems (JohnysZC)
make sure u got ur clutch cable adjusted right and check the tranny oil level.. u might be low.... or maybe u are out of adjustment... since u got a perf clutch i say maybe u need the adjustment after the break in....
Old Sep 24, 2002 | 08:17 AM
Shea-bird's Avatar
New User
Default Re: Clutch Problems (JDM EF9)
for turbo, go CM stage 3+ or act 6 puck
Old Sep 24, 2002 | 09:25 AM
JohnysZC's Avatar
Thanks for your help that makes total sense. There are also times were I have the clutch engaged and the engine moves like crazy but if I let go and then engage again it stops. I will have it checked out thanks.
Stage 3 CM doesnt sound bad neither does ACT 6 Puck. I will see after the check up.
Old Sep 24, 2002 | 09:30 AM
EL Vap133's Avatar
Go with the ACT man, I haven't had problems with them...
Old Sep 24, 2002 | 11:32 AM
JohnysZC's Avatar
Default Re: Clutch Problems (Vap133)
Your right I shall be loyal, I will tend to the problem but if it persists then I am sad to say but I have to move on.
crewdawg88crx
Dec 3, 2008 02:26 PM
1993gsrcivic
Jun 13, 2007 11:20 AM
mikeycivic
Jun 4, 2007 05:32 PM
vietdragontekx
Aug 27, 2005 06:27 PM
B00STED Si
Jan 11, 2005 03:28 PM
