Full length radiator
Old Jan 12, 2011 | 06:01 PM
LS/V-T's Avatar
Icon2 Full length radiator
Is it possible to use a full length radiator from an Integra with a turbo setup in a ek chassis?
Anybody have pics of this?
Old Jan 13, 2011 | 07:38 AM
Sohc52's Avatar
Default Re: Full length radiator
yup,
it's so common here over in my country...
just have to make 2 stays for the top and just cut and re-weld the lower mounting points to fit the teggy's mounting points...
Old Jan 13, 2011 | 09:19 AM
LS/V-T's Avatar
Do you have any pics using a Integra radiator with a boosted bseries?
Old Jan 15, 2011 | 07:10 AM
Sohc52's Avatar
boosted i dun have pics. but i know most of them running on stock teggy ones . only afew who has the budget to get a custom made turbo mani will use a mishi or koyo integra one.
Space is the key here..
I will be running one myself too.. I got GO-autoworks to custom make a ramhorn using a S259 to work with a mishi rad.. yet to have it installed.. if i drop it in, will show u pics...
here's the NA version..
Old Jan 15, 2011 | 07:46 AM
LS/V-T's Avatar
Nice pics but they aren't of an ek chassis.
Old Jan 15, 2011 | 07:53 AM
siblues's Avatar
I havent seen any with a ramhorn or top mount manifold to date.I mean the main reason for the top mount is for a bigger turbo and when you look at the pics the housing on the turbo is almost touching where the radiator mounts to and before all the know it alls chime in yes its possible to do I'm sure with enough money but I havent seen it done.
Old Jan 15, 2011 | 07:58 AM
Sohc52's Avatar
EG and EK almost the same.. it's alittle different at the headlights area only.. They mount up exactly...
any EK gusy here care to show? I remember one guy from D-series using a Full length Alu rad with ramhorn and a GT turbo...
Black EK coupe if i remember... He ran without a wastegate though..
siblues: u can.. just invest more $ and not get a turbo too big to fit.. LOL.. The turbo's gota be tilted sideways for mounting abit.. and i think u gota grind off a wee bit on the block.. really small bit..
Old Jan 15, 2011 | 07:18 PM
jetspeedz's Avatar
The only time i have ever seen a full size rad was with a log manifold, with the ram horn or top mount its virtually impossible unless you hack the hell out of the front end. Not impossible but not feasible either.
Old Jan 16, 2011 | 11:43 PM
siblues's Avatar
Here is a pic of my motor for refference I own a EM1 so the EK is the same exact thing as far as space goes
Old Feb 2, 2011 | 02:44 PM
LS/V-T's Avatar
Looks like it fit..
nick91civicsi
Mar 16, 2007 09:50 AM
billyhoe
Oct 17, 2004 03:03 PM
92HB_HB
Sep 23, 2003 07:14 PM
esponet
Acura NSX
Aug 21, 2003 04:31 PM
espanol
Jan 15, 2003 02:52 PM
