battery relocation problem
Old Jan 11, 2011 | 10:13 AM
EF9_RIDER37's Avatar
Default battery relocation problem
aite wat up guys need a little help to get this car going. so what happened a cousin and i were board and decided to relocate his battery to the back of the car. we took some time to look at the wiring and looked up how and what things we would need to approach this task. what we did was buy a distribution box and a circuit breaker to install and we followed this diagram ill post it up and when we were done everything worked lights worked everything was cool but when we try to start it it will do nothing not even a crank we tried jump starting it and nothing still we are a little stuck on this and have lost ideas we rechecked wiring grounds, see if there were any loose connections, fuses, starter, everythings seems to be good. we have lost ideas for this already
Old Jan 11, 2011 | 10:46 AM
tonythetuner®'s Avatar
Default Re: battery relocation problem
Do you still got the ground that goes from the tranny to the frame of the car??? If that ground is not there it will not crank
Old Jan 11, 2011 | 10:48 AM
But yes that diagram is correct that will work how you have it, BUT if ur cuzin plans on taking it to the track that setup will not work you will need a master cut off switch wired to the alt and battery to kill the whole car just a thought
Luke G.
12
Apr 11, 2011 08:40 PM
XxNampsterxX
Aug 2, 2008 12:20 AM
CrX-To-Tha-Max-v2.0
Dec 1, 2005 06:38 PM
DA9muthaFocka
Jan 25, 2005 05:01 PM
97itr86
Dec 26, 2004 07:07 PM
