Suspension & Brakes Theory, alignment, spring rates....
Is it possible to bend a subframe back into place?
Old Jan 10, 2011 | 12:11 PM
TwoFaced's Avatar
Default Is it possible to bend a subframe back into place?
Civic 00...possibillity subframe is bent pushing the lca about an inch towards the back of the wheel well on the drivers side.
Can I bend it back? Is there a shop that would do something like that or would they all say no hope you have to replace it?
Methods of bending it back? I'm open to all caveman-hammer-esque suggestions that might have worked for anyone else...theories...he said she said this worked ideas.
Old Jan 10, 2011 | 12:13 PM
kaiba's Avatar
Default Re: Is it possible to bend a subframe back into place?
Front or rear?
Old Jan 10, 2011 | 12:33 PM
H22AFerio's Avatar
It could be possiable. if its off an inch thats a little scary when they do bend it back that part will always be a weak point. you can order a new subframe its not to hard to install.
Old Jan 10, 2011 | 12:52 PM
TwoFaced's Avatar
Front subframe...and I found a write-up on it...and he said it took him 8 hours....looked like a helluva process.
I plan on replacing it eventually but for right now if I can bend it back to close to normal...then I'll be happy till I have more time and money. I'm primarily trying to avoid any extra tire wear if I can...right now if I hit a bump it hits the inner fender...as well as the alignment. Alignment would be pointless right now until this issue is close to fixed. Bad alignment = more tread wear = no bueno.
Old Jan 10, 2011 | 01:26 PM
H22AFerio's Avatar
ohhhh the front one! that is so easy you can have it in an out in about 3 hours
Old Jan 10, 2011 | 02:07 PM
TwoFaced's Avatar
http://repo.jackmoves.com/v/erik/album106/album139/
That's the DIY write-up I found...is that a good guide? It said it took him 8 hours to do it.
If you know of a better write-up or anything you'd do different than that please let me know if you have time to look over that.
Thanks for all the input.
Old Jan 10, 2011 | 03:43 PM
98civdx's Avatar
Master Detailer
Took us 4.5 hours to do my friends. That is if you know what your doing and have the tools to do it.
Having a buddy or 2 during the process makes a LOT easier.
Have you looked at the subframe? A inch is a lot to bend back.
After my freind slid into a curb, caused the tire to touch the fender we decided it a lot easier to swap it, not to mention we snapped 2 of the compliance bushing bolts lol
TwoFaced
15
Jan 10, 2011 06:44 PM
HooptyGSR
Mar 17, 2010 02:54 PM
Corksil
10
Sep 13, 2009 05:00 PM
fw190bvi
Sep 18, 2006 08:13 PM
Gumby99integ
Aug 23, 2006 10:29 AM
