sighns of water in oil
Old Jan 10, 2011 | 02:22 PM
94 ls-r's Avatar
Default sighns of water in oil
I have a built ls vtec and there is white oil in the oil fill cap and the driver side of head on valve cover. There is a tiny bit on passenger side of head on the cam rails. The oil in the crank case looks fine. Its a little dirty and due for a change. Coolant is also fine. Runs great and no over heat. This motor has bout 30k on it with the head and block being surfaced and I installed a oem gasket properly. Any ideas?
Old Jan 10, 2011 | 02:31 PM
hatmanafro's Avatar
Default Re: sighns of water in oil
maybe something wrong with pcv or something. maybe that white stuff is blow by.
Old Jan 10, 2011 | 02:34 PM
94VTEC2TONE's Avatar
im pretty much guessing headgasket, i had that same problem, its a milky white yellow looking ****. definetely check that
Old Jan 10, 2011 | 02:35 PM
94 ls-r's Avatar
obd2 engine block. It has not breather and I only have the hose to the intake. Anyone else hear of this? It does make sense since the location of the milky spots!
Old Jan 10, 2011 | 02:44 PM
94 ls-r's Avatar
The oil in the pan is clean of any water. There is only white built up kinda thick in certain spots. The cam rails look good except for the driver side end also? Why would it only be in 2 spots? It looks like lithium grease on the vc on the driver side only
Old Jan 10, 2011 | 03:15 PM
94 ls-r's Avatar
Someone told me it could be condensation cause it been in the thirties here but not sure. It has not used any coolant
Old Jan 10, 2011 | 04:09 PM
mouab18c1's Avatar
Condensation x 100
Old Jan 10, 2011 | 04:31 PM
94 ls-r's Avatar
The car is in my garage till I leave for work at 2 am. Its bout ten minute drive to work but the car does fully warm up. I never have seen condenstation do that to oil. I dunno what to do. Dont wanna or have the money to tear into it now
Old Jan 10, 2011 | 05:07 PM
mouab18c1's Avatar
If you coolant level is not dropping then it is condensation. Which is normal. If you are burning coolant there should be more and more of that milky stuff the longer you drive it.
Old Jan 10, 2011 | 05:18 PM
Mr. EG's Avatar
Are you using an external breather like a catchcan, hopefully considering you have this "built motor".
Old Jan 10, 2011 | 05:20 PM
fcluddington's Avatar
Originally Posted by mouab18c1
Condensation x 100
x2
94 ls-r's Avatar
Actually no. Used to have one but smashed in wreck. I hardly get on it much anymore. Can that cause the white paste in 2 spots? If it was a head gaskett I would think it would be all over?
Old Jan 10, 2011 | 05:22 PM
94 ls-r's Avatar
I gonna have my friend who knows a little more than me look at it. Then clean it up and do an oil change.
Old Jan 10, 2011 | 05:47 PM
94 ls-r's Avatar
Friend says it look like condenstaion. Gonna wipe it clean tomorrow and change oil. Just keep eye on it I guess
Old Jan 10, 2011 | 06:19 PM
94 ls-r's Avatar
Can I run half qaurt of atf to clean the motor. Its really clean but wanna flush it out good before clean oil
Old Jan 11, 2011 | 10:31 AM
Mr. EG's Avatar
No don't do that.
Old Jan 11, 2011 | 11:44 AM
94 ls-r's Avatar
No don't do that.
Any reason? Done it on old truck. Just curious why you cant do it on a honda.
Old Jan 11, 2011 | 01:45 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
wait, did I read correctly that you have NO PCV system at all?? No PCV valve in the valve cover or in a black box on the back side of the block??
Old Jan 11, 2011 | 06:24 PM
hatmanafro's Avatar
^if thats true. then theres your problem.
Old Jan 12, 2011 | 06:06 PM
94 ls-r's Avatar
Have the breather hose out of valve cover. The block is obd2. I had to ref a while back so i never put on a aftermarket breather. How can I keep it looking some what stock?
Old Jan 12, 2011 | 08:08 PM
Community Builder
Sounds to me like you have no functioning PCV system. OBD2 LS engines had the PCV valve on the valve cover, while OBD1's had it in a breather box on the block.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
This topic recommends you use a 90-95 OBD1 LS block when you do an LS/VTEC build (scroll down to where it shows the pic of the breather box), for the reason of having the PCV system in a box built onto the rear of the block. If you use an OBD2 block, you need to run an aftermarket catch can with PCV valve. Without a PCV system you will have problems with blowby vapors, condensation and other crap, and possibly blow out gaskets and seals.
Originally Posted by bambam
If you don't have this breather box or an aftermarket one installed, your motor will develop higher crankcase pressures, and a your oil will accumulate a quicker build-up of combustion by-products I.E. hydrocarbons and water.
And there you have it.
Old Jan 13, 2011 | 12:02 PM
94 ls-r's Avatar
I will get one of those breathers soon as I can. I used to have one on my high comp build but the car was hit and smashed it. Then ref soon as car back together. I never get on it much and baby it alot cause I know I need one. Is there any ones that are better for any reason?
sohcpower1
May 8, 2016 11:08 AM
lalocivic
38
Oct 20, 2009 08:09 AM
aziaticvang
12
Feb 5, 2008 07:08 PM
doggworld1233
20
Dec 8, 2005 05:27 PM
louviljlj
Feb 8, 2005 03:01 PM
