Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Mazworx D2B Adapter Kit | D-Series w/B-series transmission
Old Jan 10, 2011 | 12:05 PM
MazworxRacing's Avatar
Default Mazworx D2B Adapter Kit | D-Series w/B-series transmission
Available now for 92-95 Civic's! Available for the 88-91 Civic/CRX Taking pre-orders!!!!!
We are proud to release our D2B adapter kit. This will let you use a B-series transmission to any D-series engine. The kit comes complete with all hardware needed to be a bolt on application. It also lets you use the B-series axles and intermediate shaft. All you will need to do is send us your B-series bellhousing so we can machine it and set dowel pins in for you.
The kit includes:
Mazworx D2B transmission adapter plate
Mazworx D2B driver side mount ( uses 3 post mount) If you dont already have this mount, it is available through Honda with part#
11910-P07-000 - mount
90041-P07-000 - left stud
90042-P72-000 - right stud
Mazworx D2B intermediate shaft bracket
Mazworx D2B Rear transmission t-bracket.
All bolts and hardware.
Get this kit paired up with a Competition Clutch steel flywheel made for D-series crank/B-series clutch for $829.00 SHIPPED!
At the moment, the kit is available for the 92-95 Civic (EG). The 88-91 Civic/CRX ( EF), and 96-00 Civic (EK) will be available soon.
Please PM, email or call us if you have any other questions.
Old Jan 10, 2011 | 04:26 PM
Mr. EG's Avatar
Default Re: Mazworx D2B Adapter Kit | D-Series w/B-series transmission
very sweet, good job
Old Jan 11, 2011 | 07:49 AM
PM's replied Thanks!
Old Jan 12, 2011 | 12:57 PM
www.mazworx.com
Old Jan 13, 2011 | 08:03 AM
Old Jan 14, 2011 | 11:52 AM
Old Jan 17, 2011 | 05:50 AM
Old Jan 17, 2011 | 01:59 PM
Old Jan 18, 2011 | 07:25 AM
Old Jan 20, 2011 | 05:36 AM
Old Jan 21, 2011 | 07:16 AM
Old Jan 25, 2011 | 08:11 AM
Old Jan 26, 2011 | 12:25 PM
You will first install supplied dowel pins into the block. This will aid in the proper alignment of the adapter and transmission.
Then you will install the adapter plate to the block and install 2 provided bolts on the right side of the plate.
Bolting of the axle bracket assembly to the block
Transmission bolted onto the plate using the factory top 2 bolts and lower right one behind the slave cylinder provided.Then all you do is bolt the supplied rear t-bracket, factory trans upper mount and provided driver side mount and drop the motor back in.
Old Jan 26, 2011 | 12:53 PM
BLK2DOOR's Avatar
Nice work guys!!!
Old Jan 31, 2011 | 12:03 PM
Old Feb 3, 2011 | 10:14 AM
Old Feb 4, 2011 | 12:06 PM
Old Feb 7, 2011 | 12:11 PM
Pm's replied Thanks!
Old Feb 10, 2011 | 06:59 AM
Old Feb 14, 2011 | 12:20 PM
Old Feb 23, 2011 | 08:47 AM
Old Mar 10, 2011 | 08:27 AM
Old Mar 14, 2011 | 01:19 PM
Old Mar 22, 2011 | 01:24 PM
Old Mar 28, 2011 | 01:44 PM
