Grinding/clunking noises while making right turns - 96 hatch
Old Jan 9, 2011 | 09:32 PM
J.HA's Avatar
Default Grinding/clunking noises while making right turns - 96 hatch
Back in the past, I had a similar problem where my rear trailing arms would clunk when I make left/right turns. I found out that my RTA bushings were shot and I replaced them with brand new OEM ones. Its been 4 months now and similar grinding noises occur when I make right turns only. The sound is coming from my rear passenger side. This only occurs within the first 2-3 right turns I make while driving, other than that it goes away until my next drive. What are the possibilities? My car is a 96 hatch by the way. Thanks
Old Jan 10, 2011 | 12:49 PM
J.HA's Avatar
Default Re: Grinding/clunking noises while making right turns - 96 hatch
Matter of fact, it also clunks when the car jerks while shifting..coming from the rear.
Old Jan 10, 2011 | 01:15 PM
8YourV8's Avatar
LCA bushings?
Old Jan 10, 2011 | 06:26 PM
J.HA's Avatar
I recently changed them 4 months ago with brand new OEM ones..Are there any other possibilities? I will have to take a look when I have time. Thanks
Old Jan 10, 2011 | 07:07 PM
wheelmanbg's Avatar
Did you change all the bushings?
You said you replaced the trailing arm bushings with new OEM. Did you clock them right?
Mccormick009
Sep 25, 2014 09:23 AM
J.HA
Jul 8, 2010 01:42 PM
96hb
Suspension & Brakes
12
Mar 8, 2010 07:08 AM
SGVridgerunner
Apr 26, 2007 05:44 AM
