HELP: Restoring OEM lip and bumper - Filler to use?
Old Jan 9, 2011 | 06:42 PM
SoFresh's Avatar
Default HELP: Restoring OEM lip and bumper - Filler to use?
Hey guys,
I searched the sticky DIY threads.... mainly were for carbon fiber or abs crack repairs... I have an OEM 2000 Civic SI front lip I want to repair... not cracked or anything, just scuffed up on the underside and some small gouges in it from previous owner scraping. I am painting the entire car soon and need to know what type of filler is okay to use on the OEM Honda material on the front lower lip, also the prep process for it.
Also, have a little gouge on the OEM rear bumper, what type of filler is okay to use in this situation that will adhere to OEM bumpers, etc.
Thanks in advance.
Old Jan 9, 2011 | 08:46 PM
gorillafart's Avatar
Default Re: HELP: Restoring OEM lip and bumper - Filler to use?
abs = plastic. use watever they used.
Old Jan 10, 2011 | 07:33 AM
prelude1897's Avatar
I've used body filler to fix front lips and bumpers and haven't had any issues. Be sure to scuff the bumper up real good before applying the filler.
Old Jan 10, 2011 | 01:46 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
SEM bumper repair, this stuff is awesome!
Old Jan 10, 2011 | 01:47 PM
SoFresh's Avatar
Thanks PhantoM! I love SEM products. I am going to track some of this down. Is it easy to sand?
Old Jan 11, 2011 | 10:26 AM
Hawkze_2.3's Avatar
If you want easy to sand use 3M Automix, it is designed for use on plastic.
Old Jan 12, 2011 | 10:41 AM
eksessiv's Avatar
Get the 3M stuff. Works great. I would stay away from filler if you want to do it right. Not saying it could not work, but there are better ways to fix it.
Old Jan 17, 2011 | 11:27 AM
ekhatchey's Avatar
the sem stuff is great i recently shaved the licence plate holes and used the sem stuff to fill and smooth it out but it sets really fast and can be sanded with in a few min was pretty easy to clean it up (only bad thing is is smells like crap untill its completely cured about a day or so but its outside so u wont have to smell it )
Old Jan 17, 2011 | 07:29 PM
siblues's Avatar
I always thought these types of fixes expand and contract at a different rate then the bumper material causing the paint to crack unless the flex in the paint will be able to handle it?Just asking out of curiosity
Old Jan 18, 2011 | 04:25 PM
JSPECSIR's Avatar
fusor 114 and sem problem plastic repair are good. you will also need all the cleaning and scuffing agents and adhesion promotor to go with the product you are using. dont think you can sand it and just slap it on there. plastic repair doesnt work that way.
Old Jan 18, 2011 | 05:30 PM
TunerN00b's Avatar
That thought process is why some people plastic weld for show cars instead of using filler, to prevent any "body filler" issues from ever happening.
Get an old bumper from a junkyard (or a proper plastic welding rod), cut a piece slightly larger than you need to repair yours, weld in. No filler, no worries.
SoFresh
Paint and Body
Aug 20, 2011 08:23 PM
DEATHB4DlSHONOR
Mar 6, 2010 05:19 AM
brutekiller787
Jan 23, 2009 03:28 PM
YoungMoneySi
Nov 30, 2008 12:14 PM
