New 94'' accord owner need help with repairs!!!!! please! og here!!
Old Jan 9, 2011 | 06:20 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default New 94'' accord owner need help with repairs!!!!! please! og here!!
Whats up Accord guys! i need your help, i got a 94'' accord for my baby mamma and it needs some work!, im no noob and i own a 98'' ITR and built the entire thing from scratch but this accord is killing me! it has no vss! the car doesnt blow hot air! and i need some oem accord rims. It didnt pass smog either. I need help locating why the blower doesnt blow hot air! where should i look. check engine light comes on but im pretty sure its cause it has no vss, how do i check that? also the intake arm is torn below cause the oem intake has two pieces and the lower port is torn from the upper arm, and if any one has oem accord rims with good tires in s.d lmk asap thanks.
Old Jan 9, 2011 | 06:34 PM
nus_dogg's Avatar
Default Re: New 94'' accord owner need help with repairs!!!!! please! og here!!
I'd get a VSS if there's none. As for not blowing hot air? I'd check the heater control valve located by the firewall if you follow the heater hose located underneath the distributor from the head back and it's a small black plastic control valve. Usually on these Accord, those heater valve stuck close which allows no coolant to flow to the heater core for heat.
Since your's a '94 Accord, there's a blue two pin connector under the passenger side dash, unplug it and jump the two pin connector with a paper clip or some sort with the key to the "ON" position. It'll give you so many long and short flashes. Example, it gave you two long flashes and two short flashes, thats code 22. Hope this helps.
Old Jan 9, 2011 | 06:37 PM
chikin pickle's Avatar
Can't help you with emissions unless you have test results. Emissions differ in every state, as do limits. Some states use parts per million as a measurement. My state (az) uses grams per mile.
Old Jan 9, 2011 | 08:59 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
So the ODO isn;t working? or you're saying the actual VSS sensor on the tranny IIRC is not there?, sorry your statement isn't clear.
As for the heater not blowing in hot air, you could have a blockage. This video will explain your situation.
http://www.youtube.com/watch?v=dcL_0...layer_embedded
As for smog testing start by finding out what codes there are in your check engine light this will tell you if it's emissions related or VSS related.
Old Jan 9, 2011 | 09:19 PM
wunfstgsr's Avatar
Loved
Community Favorite
Hey thanks nus_dogg! ill check that tomarrow dude!, yea i saw that and i figured maybe i can bypass it like the obd1 b series ecu's!
Damn never knew that! thanks bro.
No the odom isnt working, the actual vss aint there lol that explained it once i took a look when i removed the air box. I wonder why its missing! this car was real janky! no radio, big 17'' pos tsc rims with the low profile tires, this is why i need the oem rims, all the pot holes around s.d after the rains left one of the rims bent! now heres a ugly unsafe donut on! she drives the baby so i get nervouse with the rims on there.
I believe it was checked previously and was diognosed with a bad knock sensor! which i dont see why, and vss malfunction, but there isnt even a vss there. so im guessing the check engine light that randomly comes on is still the vss cell. it has to be.. thanks for the help guys!
Old Jan 9, 2011 | 09:38 PM
kevinthefawker's Avatar
if you need help checking /repairing the stuff i can give you a hand. i had a few accords before and im local sd also
Old Jan 9, 2011 | 09:46 PM
wunfstgsr's Avatar
Loved
Community Favorite
Thanks dude! have you ever had a bad heater core or had this happen to any of your accords?
Old Jan 9, 2011 | 10:04 PM
Community Builder
I would try flushing the heater core instead of ripping apart the dash.
I suspect my accord has partial blockage of the heater core because my prior accord the heat was toasty this accord the heat is lukewarm. When winter passes I'm going to this procedure.
BTW, if you do flush the system a garden hose is acceptable because you're simply applying pressure to force out any gunk.
As for the VSS since it isn't there install one.
Old Jan 9, 2011 | 10:11 PM
wunfstgsr's Avatar
Loved
Community Favorite
Im not sure what hose to flush, should i drain the radiator and just flush the upper radiator hose? or the lower hose and drain the upper hose in a bucket..
Old Jan 9, 2011 | 11:05 PM
Community Builder
did you not watch the video?
Old Jan 10, 2011 | 01:05 AM
wunfstgsr's Avatar
Loved
Community Favorite
yea i get the concept but the car wasnt a accord.
Old Jan 10, 2011 | 01:06 PM
Community Builder
Same procedure, drain your coolant locate heater core hoses by using your lower radiator hose, you'll notice 2 smaller hoses they will go into the firewall in the vicinity of the throttle body (beneath it).
Disconnect both hoses, one will be inlet and outlet hoses and start the flushing procedure.
Old Jan 10, 2011 | 04:47 PM
nada i had 4 of them from 0miles to 300k miles and none of them had bad heater cores, it could be the valve is stuck or the cable broke
Old Jan 10, 2011 | 05:33 PM
sublime423's Avatar
HOLD ON!
Before you go flushing and all that with the heater check the simple things first, broken temp ****. It can stay on the panel and turn fine but can have cracks in it that would change it over to hot. broken ***** are way more common that clogged heater cores.
also the cable can be out of adjustment too like one of the first poster implied with checking the hot water valve if the valve is open and no heat then you got a problem.
changing coolant will not help heater proformance and I wouldn't recomend "flushing" unless it was absolutely needed.
Old Jan 11, 2011 | 11:12 AM
wunfstgsr's Avatar
Loved
Community Favorite
Originally Posted by sublime423
HOLD ON!
Thanks man, where is that temp **** and hot water water valve located or is that what nuss_dogg was explaining?
Old Jan 11, 2011 | 02:49 PM
wunfstgsr's Avatar
Loved
Community Favorite
also the egnition key hole is jamed or something cause its hard to get the key out sometimes, you have to push in and turn to release but it wont sometimes and it gets fustrating, do i need a new ignition and will that be a pricey fix and hard to install?
Old Jan 11, 2011 | 07:20 PM
sublime423's Avatar
The temp **** is on the dash it's what you turn to make it cold or hot.
the water valve is near the firewall below the intake manifold. follow the heater hoses.
Old Jan 11, 2011 | 07:25 PM
wunfstgsr's Avatar
Loved
Community Favorite
ow duh lol how do i confirm the **** is broken? it seems to turn fine..
Old Jan 12, 2011 | 03:07 AM
Community Builder
Are you sure you built a car from scratch? from what I am reading in your posts you are asking questions to pretty basic procedures.
Anyway, remove heater **** and see if it's broken. I doubt that it is since you said it turns fine but check anyway.
This is your heater valve
Old Jan 12, 2011 | 10:50 AM
wunfstgsr's Avatar
Loved
Community Favorite
lol you bet your a$$! i had this gsr pretty much stripped and bare at one time! I dont just go and tear things up, i like to know the proper way to disassemble the part or project thats all.
https://honda-tech.com/forums/showth...2556604&page=5
thanks for the pic!
Old Jan 12, 2011 | 11:05 AM
Kronn 98SH's Avatar
Have you thought about getting the Helms manual for it?
Old Jan 13, 2011 | 06:12 PM
wunfstgsr's Avatar
Loved
Community Favorite
No but im sure it would come in handy! ill update when i get a chance to work on the car.
Old Jan 14, 2011 | 10:32 PM
phootbag's Avatar
The 1994 Accord produced before August had a problem with the heater cable noob coming undone due to a poorly designed clip. Depending on the actual noob production month this could be your problem. You should observe the heater valve movement noob to confirm it moves when you adjust the noob temperature control ****.
The VSS can be checked by confirming an output signal noob from the VSS feedback wire with the front wheels rotating, key on. This can be tricky if you don't have the proper diagnostic tools noob or an electrical schematic detailing the proper wire. Or, you can put one where that hole is in the transmission.
The failure of the smog check could be caused by too many things to guess. As stated, a printout of the noob actual readings will be necessary to start directing your efforts.
And, best wishes to your baby momma.
Old Jan 15, 2011 | 07:09 AM
dansaleen_04's Avatar
[QUOTE=kidcool1977;44407857]Are you sure you built a car from scratch? from what I am reading in your posts you are asking questions to pretty basic procedures.
Actually that is not true. I can vouche for a damaged heater control **** mechanism being broken. I would turn it and it felt fine like it was suppose to turn but wouldnt change the temp. When we took it apart the mechanism inside was broken.
Old Jan 15, 2011 | 07:18 PM
wunfstgsr's Avatar
Loved
Community Favorite
[QUOTE=dansaleen_04;44431813]
Ill check the heater core **** asap, heres my build thread on my sleaper please leave your comments if you care to see the car i built,
