is my 60mm exhaust too restrictive if i have open waste gates?
i have a 92 civic hatch that is only in its early stages of making power. i have a 60mm skunk 2 catback with 3 inch down pipe. fully built head and sleeved block, the whole 9 yards. i have dual 40mm tial wastegates using a gt35r and i would like to know if this exhaust is going to be too restrictive even though i have 2 Tial 40mm wastegates WITH OPEN DUMP. im only on 12psi right now but will be retuning/turning the boost up in spring.
thanks, Doug
thanks, Doug
thanks, Doug
thanks, Doug
definitely get a bigger exhaust. This isnt some D-series running a t25, you're going to need something much bigger
I have a setup pretty similar to yours (84.5mm B18C w/ GT3076) and I run a 60mm exhaust. It "feels" pretty restricted in the upper RPM. I installed a cutout in my downpipe and when the cutout is open it feels like it has a TON more up top. It ran so much leaner that I had to build myself secondary fuel-maps for when the cut-out is open. Plan to head to the dyno ASAP for quantitative results.
mandrel bend 2.5" will support enough flow up to 300hp ish
running up to 300hp with 3" mandrel bend will help with spool time and give u a louder exhaust note.
i personally would run 3" if i ran anything more than 250hp that is turboed
aleks77
May 14, 2007 09:26 PM
dezerte
Mar 8, 2007 06:57 AM
