Best 1993 Honda Civic DX Coup Engine/Turbo Combo
Old Jan 8, 2011 | 05:04 PM
JordanStallion's Avatar
Icon6 Best 1993 Honda Civic DX Coup Engine/Turbo Combo
I'm Running a 1993 Honda Civic DX Coupe
What is the BEST 9.0:1 compression ration engine to get that will work with the best results with a turbo?
Old Jan 8, 2011 | 05:28 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Best 1993 Honda Civic DX Coup Engine/Turbo Combo
Power goals? Budget? Compression ratio has nothing to do with it really.
Old Jan 8, 2011 | 05:36 PM
apexi_rsx's Avatar
stock compression is 9:4 it would spool faster with a higher compression but the higher the compression the more prone to detonation but can spool the turbo faster and sooner,but less likely u can use pump gas. lower comp u can run pump gas and lot more room for error in your tune.
Old Jan 8, 2011 | 05:38 PM
I'm looking at 4-5k in parts consisting of transmission, engine, ecu, axels, shifter cables, shifter assembly, alternator, starter, clutch flywheel, intake/exhaust manifold, fuel rail, injectors, distributor, engine harness, and all the sensors. Looking at getting a complete change over and adding a turbo after i install the engine and everything.
Old Jan 8, 2011 | 05:41 PM
The engine I'm looking at this H22A (http://www.hmotorsonline.com/shop/sc...age&item=30017). Would it be a good engine for a turbo or would it be counterproductive??
Old Jan 8, 2011 | 11:52 PM
riceburnerryan's Avatar
there is a sticky at the top of the forum, FAQ and it has an entire section regarding swaps and which can make the power goal that meets your needs
88hbz6
Nov 25, 2008 07:48 PM
aimbot
Apr 24, 2007 12:16 PM
dinku27
Sep 12, 2005 05:28 AM
extra cam needed
Jun 30, 2005 07:26 PM
MUGENTYPER
Feb 6, 2002 12:04 AM
