About to buy a 93 Si, Swap Recommendations..
Old Sep 23, 2002 | 10:02 PM
JBG's Ferio's Avatar
Default About to buy a 93 Si, Swap Recommendations..
What would you guys recommend I swap into it. Or what do you think i should do. Thanks in advance for the advice.
Old Sep 23, 2002 | 10:19 PM
stevel's Avatar
Default Re: About to buy a 93 Si, Swap Recommendations.. (J B G)
damn man. You could be a little more specific. That's why people harp on noobs so much. Specifics is they key.
What are you looking to achieve? Short term and long term?
What purpose is it gonna be built for? Street/Strip/HPDE's/etc? Is it gonna be a daily driver? Do you want to go turbo or NA? And the biggest deciding factor, how much money do you have to spend?
You should ask yourself those questions and figure it out. I wouldn't bother necessarily posting your answers here but read up a lot on what you're looking to do so you can gain the knowledge necessary to make your own decision. Don't ask someone else to make it for you. Hint: use the search function. It works quite well. Just my $.02!
s
Old Sep 23, 2002 | 10:46 PM
InfamousRS's Avatar
hmmm.... Send a b18a/b to GEM for sleevs and deck plate, Eagle 95mm crank, 13:1 cr 86mm pistons, cutom eagle rods, b16 head p & p by Alaniz, Rockets "toda killer" cams, TWM ITBs, race gas....its the only way to go!
Old Sep 23, 2002 | 11:01 PM
Default Re: About to buy a 93 Si, Swap Recommendations.. (stevel)
sorry bro, it's gonna be a DD. I definitely want all motor. I've thought about getting a gsr block, itr head, itr pistons, toda spec b's, toda valvetrain, itr tranny, itr ecu.
Old Sep 23, 2002 | 11:51 PM
e_SolSi's Avatar
why not just buy an itr swap and put the toda stuff in it ?? probly be a hell of a lot cheaper than buying all of those parts sepratly
Old Sep 24, 2002 | 01:39 AM
Default Re: About to buy a 93 Si, Swap Recommendations.. (e_SolSi)
Just throwin out some ideas to see what you guys think.
Old Sep 24, 2002 | 09:13 PM
Ferrell's Avatar
i think you are a tool
i also think that you should get NAWZ for that sohc
Old Sep 25, 2002 | 06:48 AM
Default Re: About to buy a 93 Si, Swap Recommendations.. (Ferrell)
Man, do you drive an ITR?
Old Sep 25, 2002 | 08:45 AM
Chrislow's Avatar
Old Sep 25, 2002 | 10:21 AM
hybrider's Avatar
Default Re: About to buy a 93 Si, Swap Recommendations.. (Chrislow)
im happy with my b18c, even though the si is a pig.....
Old Sep 25, 2002 | 11:42 AM
SuperCivic's Avatar
Default Re: About to buy a 93 Si, Swap Recommendations.. (hybrider93)
get a full GSR swap. if you've never ridden in one before, you'll be pleasantly surprised with the results. and you'll only have to drop around 3k if you do the install yourself.
Old Sep 25, 2002 | 01:33 PM
X2BOARD's Avatar
Default Re: About to buy a 93 Si, Swap Recommendations.. (SuperCivic)
Old Sep 25, 2002 | 06:41 PM
myhatchrips's Avatar
jdm gsr!!
my setup:
94 civic si no front or rear seats
94 jdm gsr motor
dc jdm 4-1 header (open header for track day)
chipped p28 ecu 5700 vtec engagement
b&m fuel pressure regulator and gauge
civic type r intake and exhaust cams
stock cam gears
stock intake manifold
stock throttle body
stock clutch
nitto 555 drag radials on 14 inch steelies
1/4 mile e.t.=13.639 at 101.76
60 foot time= 2.1
your call but this motor was worth every penny!
Old Sep 25, 2002 | 10:08 PM
Ferrell's Avatar
No, but never said i did?
BTW, why are joo asking about this....... plan on building a Revell 1:24 scale Hybrid?
Old Sep 25, 2002 | 10:38 PM
Al Bundy's Avatar
Default Re: About to buy a 93 Si, Swap Recommendations.. (myhatchrips)
jdm gsr!!
my setup:
94 jdm gsr motor
stock cam gears
stock throttle body
stock clutch
60 foot time= 2.1
How'd you run that time with no front seats?
Old Sep 26, 2002 | 10:10 AM
You building a revell 1/24 scale hybrid?
haha yea, can you let me borrow an itr sales brochure? i need to frame a couple pages. :D
[Modified by J B G, 11:11 AM 9/26/2002]
Old Sep 26, 2002 | 10:25 AM
00WhiteEKy's Avatar
gsr all way dude! If you have the extra $$, get a itr. But I love my gsr. I plan to go boost, so gsr was my pick. its fun as hell. corvette's get pissed when you take them at stop lights! (not z06's though)
Va99hatch
Apr 12, 2012 07:02 PM
816RJE
11
Dec 8, 2008 09:05 PM
baller78c4life
12
Oct 26, 2005 10:11 AM
projectTeG
Mar 15, 2004 08:46 PM
