ECU compatibility
was trying to find a ECU for my auto to manual swap, found one but I think the guy has no clue(like I do) if this ECU will go into my 97 EX D16Y8 manual tranny, can someone please let me know if this will fit:
code on the ECU is:
57820-P2E-A01
900-141053
EE
code on the ECU is:
57820-P2E-A01
900-141053
EE
What you posted above
P2E = d16y7 motors 96-00 civic A>50 is manual : above a<50 is auto
p2p ao1 = d16y8 motors 96-00 civic
LOOK for a [ p2p ao1 >> p2p << ao2 d16y8 motor ]
if you get that ECU you wont run vtec and possibly slower you might be able to convert your current ecu to manual it works for OBD1 ecus not sure for obd2. if not get a obd2a - obd1 jumper harness with a chipped ecu for a d16y8 will cost you about $150-200
Code: OBD: VTEC: Found In:
P05 1 no 1992-1995 Honda Civic CX
P06 1 no 1992-1995 Honda Civic DX
P07 1 yes 1992-1995 Honda Civic VX
P08 1 yes 1992-1995 Honda Civic D15B (JDM)
P0A 1 yes 1994-1995 Honda Accord EX
P0A 0 no 1990-1995 Honda Accord F22A
P13 1 yes 1992-1995 Honda Prelude VTEC (H22A)
P14 1 no 1992-1995 Honda Prelude Si (H23A)
P27 1 yes 1992-1995 Honda Civic EG JDM1600 SOHC
P28 1 yes 1992-1995 Honda Civic EX/Si / del Sol Si
P2E 2 no 1996-1998 Honda Civic DX
P2M 2 yes 1996-2000 Honda Civic (NZ) SOHC VTEC
P2N 2 no 1996-2000 Honda Civic HX
P2P 2 yes 1996-2000 Honda Civic EX (D16Y8)
P2T 2b yes 1999-2000 Honda Civic Si
P30 1 yes 1992-1995 Honda del Sol DOHC VTEC EG/SiR
P54-G31 1 yes 1997 Honda Accord 1.8 LS (EDM)
P5P 2 yes 1996-1999 Honda Prelude (H22A)Type SH / Type S(JDM)
P61 1 yes 1992-1993 Acura Integra GSR (B17A)
P72 1 yes 1994-1995 Acura Integra GSR
P72 2 yes 1996-2000 Acura Integra GSR
P72 2 yes 1996-1999 Acura Integra GSR B18C
P73 2 yes 1996-2000 Acura Integra Type R (JDM and USDM)
P74 1 no 1992-1995 Acura Integra LS/GS
P75 1 no 1992-1995 Acura Integra LS/GS
P75 2 no 1996-2000 Acura Integra LS/GS
PBA 2 yes 1997-2000 Acura 1.6 EL (Canada)
PCT 2 yes 1997-2001 Honda JDM ITR/CTR
PCX 2b yes 1999-2001 Honda S2000
PG6 0 no 1988-1989 Acura Integra, All Models
PM5 0 no 1988-1991 Honda Civic/CRX DX
PM6 0 no 1988-1991 Honda Civic/CRX SOHC Si
PM7 0 no 1988-1991 Honda ZC (JDM EF)
PM8 0 no 1988-1991 Honda CRX HF
PR2 0 no 1988-1991 Honda ZC (EDM)
PR3 0 yes 1989-1991 Acura Integra XSi/RSi
PR3-J00 0 yes 1992 Acura Integra JDM B16A EF 8/9
PR3-J51 0 yes 1992 Acura Integra JDM B16A EF 8/9
PR4 0 no 1990-1993 Acura Integra LS/GS
PR4 2 no 1996-1999 Acura Integra LS/GS/RS (B18B)
PS9 0 no 1988-1991 Honda Civic 4-door EX Automatic
PW0 0 yes 1989-1991 Honda Civic/CRX SiR (or auto from 90-91 Integra XSi)
bam there you go
bam there you go
I have a 1990 civic hatchback. I have a d15b1 motor in it right now planning on switching to a d16y8 was wondering what all I would need as far as if I needed a new wiring harness of if the old one would fit the new engine. Also do I need a new ecu cv axle etc...
Might be a stupid question but I’m new to this just trying to figure everything out
bam there you go
bam there you go
I currently have a d16a8 twincam motor with a p27 k01 but sometimes it starts sometimes it dont.
But you can see it is burnt but what i want to know is what other ecu will work without changing anything else?
Hi, I have a standard honda ballade luxline 160i, 1995 D16A7,
my code on ecu is 37820-p27-k01, i cant find anywhere an ecu, can you maybe advise a different one that would work for me please?
BattleBun
Jan 31, 2018 04:20 AM
Chrisjvargas
May 25, 2015 02:45 PM
irideslammed5021
Jun 29, 2006 11:45 AM
