Where is this leak? *Pics*
Can anybody help me figure out where this leak is coming from? Is it coming from the oil pan? If it is why does it look like its leaking from the bolt above the oil pan? Thanks
The leak appears to be above the drain bolt. On the V6, the pressure switches are not directly above the drain bolt. There is a plug above on the engine block; but, my guess would be the valve cover gaskets.
I thought that was the maintenance hole like the F & H Series block where you insert something long to go lock the rear balance shaft til OP said it was a V6.
I still think it may be leaking from the valve cover gaskets, as I don't see anything else it may be from above.
Imma try to clean that area real good tomorrow with engine cleaner/brake cleaner and let the engine run to see where that leak is coming from. Best bet is the Valve Cover Gasket.
To me, it looks like #13 is the oil filter housing gasket. Your leak looks to be further in. It also appears that some type of sealant was used around various surfaces. Is this motor rebuilt?
Torino117
Oct 18, 2014 07:31 AM
