ARP head stud question (with cometic head gasket)
Old Sep 23, 2002 | 09:19 PM
infamousALLMTR's Avatar
Default ARP head stud question (with cometic head gasket)
I have a B18b1 block with ARP head studs and a custom Cometic head gasket, my question is what should I torque the head studs down to?
Old Sep 24, 2002 | 06:54 AM
sweet's Avatar
Default Re: ARP head stud question (infamousRRH)
when i installed ARP studs on my B18C1 motor the instructions said to install them hand tight with the supplied ARP lube. i installed them hand tight using a rag/cloth for the most grip, with the lube of course. i also used a stock sized Cometic HG. everything's working fine. hope this helps.
later
Old Sep 24, 2002 | 09:45 AM
Shft@9GSR's Avatar
Sweet is correct on setting the studs before torquing.
[Modified by Shft@9GSR, 6:45 PM 9/24/2002]
Old Sep 24, 2002 | 09:59 AM
Default Re: ARP head stud question (Shft@9GSR)
got that but now I need to torque the head down... do I torque stock specifications? or do I do what arp wants torqued?
edit- called arp and they told me 65 lbs on the head with moly lube.
[Modified by infamousRRH, 11:09 AM 9/24/2002]
Old Sep 24, 2002 | 11:01 AM
sweet's Avatar
do what ARP says since you are using their studs. i talked to them when i did my buildup and they explained that the torque specs are different because of the stud material and the lube that is used. so i just followed what they said and i haven't had any problems yet.
later
( o )( o )
Jun 2, 2012 04:13 AM
chrisfromsrq
Sep 21, 2009 11:39 AM
b17 rolla
Jan 12, 2009 09:01 PM
dornon13
Dec 17, 2004 01:11 AM
fmfkid250
Mar 3, 2004 08:41 AM
