91 Honda Loses electric Power when revving
Old Jan 6, 2011 | 07:45 AM
NotoriousCRV's Avatar
Default 91 Honda Loses electric Power when revving
I have 1991 Honda Civic with a d15b1 dual point that loses power when i give it throttle. The headlights dim, the stero cuts out, and under hard throttle the motor wants to cut out. It started after i put in a front strut bar. I unninstalled it and i cant find the problem!
Old Jan 6, 2011 | 08:48 AM
KINGVEM^^ED6's Avatar
Default Re: 91 Honda Loses electric Power when revving
alternator?
Old Jan 6, 2011 | 09:42 AM
jlk16188's Avatar
pull the pass side carpet back and look at the ecu. I bet its blinking code 16 electrical load detector. Mine went bad too. You'll need to replace the entire under hood fuse panel bc it is built into it. They are cheap and easy to find. Took me less than 10 mins to change and all problems were solved
Old Jan 6, 2011 | 11:56 AM
tonythetuner®'s Avatar
Yep wat they said eaither alternator. Or your eld. Both with cause problems your describing. If you don't got a code 16 or any other codes take your alternator some place to get tested
Old Jan 6, 2011 | 01:20 PM
ok ill try that this weekend and also i forgot to add that also when i give it throttle my temp guage goes all the way up
Old Jan 7, 2011 | 08:34 PM
No codes just checked tonight
Old Jan 7, 2011 | 09:03 PM
wen its idleing pull off the negative cable from the battery if it dies its ur alt
Old Jan 8, 2011 | 06:50 PM
It ran fine when i pulled off the neg. cable while running. the steroe cuts out when played half way volume and louder while the car is off
Old Jan 9, 2011 | 02:55 AM
xxxletdownxxx's Avatar
when the car is off and the key is at acc or off completely?
Old Jan 9, 2011 | 04:39 AM
andyz's Avatar
I found the temp gauge is inaccurate until you get a solid electrical system going.
Old Jan 9, 2011 | 07:26 AM
At acc is when it cuts off, but the lights dont dim while the car is off either im so confused lol
Old Jan 9, 2011 | 08:58 AM
95coupelsv's Avatar
did you replace the alternator yet cause that would be my thought. good luck!
Old Jan 9, 2011 | 02:31 PM
i dont think its the alternator its gotta be something else
Old Jan 10, 2011 | 05:21 AM
jlk16188's Avatar
im telling ya, change out the under hood fuse box and it will prob work fine. you can find them used all over the internet or junk yards
Old Jan 10, 2011 | 07:06 AM
Jockone's Avatar
Is the belt tight? Does the car make any noise?
Old Jan 10, 2011 | 07:35 AM
Sorry i missed your previous post ill try this out and let you know
Also the car doesnt have any noises and the alternator belt is tight and working
Old Jan 10, 2011 | 02:31 PM
Jockone's Avatar
Code 16 is fuel injector.
Code 20 is the ELD.
Old Jan 10, 2011 | 05:26 PM
seanewing's Avatar
i had the same problem a week ago my power cable (black wire runs to positive battery terminal) was loose i just tightened it up and its run fine ever since hope that helps and good luck
bigchale
Honda Civic (2001 - 2005)
Oct 3, 2015 06:07 PM
91civicwa
Mar 9, 2013 10:54 AM
killakalipoph
Aug 20, 2011 06:20 PM
civicstar
Mar 6, 2008 09:56 PM
samurablaze
Nov 8, 2005 06:31 PM
