Fog Light Install Instructions
Old Jan 5, 2011 | 09:10 PM
plaidjppatches's Avatar
Default Fog Light Install Instructions
I just got my fog lights in the mail and i was wondering if anyone had any instructions on how to install them. 1997 Lx Accord 4dr
Old Jan 6, 2011 | 05:19 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Fog Light Install Instructions
OEM? DEPO? random eBay crap?
Old Jan 6, 2011 | 08:03 AM
cd6 cd7 oem stanley fogs
Old Jan 6, 2011 | 08:14 AM
nus_dogg's Avatar
Wait, did it come with the Harness A and B? Harness A would be the interior harness while B is the exterior harness that goes to the Fogs.
Old Jan 6, 2011 | 08:37 AM
Bingo, there are two harnesses, A and B. The quick explanation is one is strung from the driver's side (behind turn signal) across the front zip tied to the bottom and then ends below the battery tray/coolant overflow. The second harness connects to that there, then goes up to the battery tie down where a relay and bracket are secured then goes to the fuse box where a plug is plugged in. The little bit of wiring you have left then goes from the fuse box down to the bottom of the firewall below the throttle body to a plastic grommet. You remove the grommet and remove the sound deadening from the inside and run the wire up to where the clock and hazard switch is.
Old Jan 6, 2011 | 08:38 AM
I am however going to wager if you bought them on eBay you just got the cut off pigtails and the lights themselves. To my knowledge I purchased the last OEM 96/97 foglight set in the country from Majestic Honda.
Old Jan 6, 2011 | 10:27 AM
I got just wire harness b looks like I need to find a
Old Jan 6, 2011 | 10:39 AM
They should have sticker labels on them indicating which harness they are, just as an FYI.
I doubt you will find the harnesses separated from the fogs for sale. Best bet is either a junkyard or buy a second set and cannibalize. Alternatively use an aftermarket foglight harness.
Old Jan 6, 2011 | 11:09 AM
redbull-1's Avatar
Here are the instructions:
http://www.hondaautomotiveparts.com/.../17995_01.html
Old Jan 6, 2011 | 02:39 PM
nus_dogg's Avatar
^^ Nice. I tried to find that DIY link but couldn't.
enot767
Feb 27, 2009 02:23 AM
RIZOBIZERT
Honda Civic (2001 - 2005)
Dec 1, 2007 05:13 AM
flyingduck04
27
Dec 30, 2006 03:52 PM
elnoyl
Oct 2, 2003 07:52 AM
