Ajustable camber upper control arms problems
Old Jan 5, 2011 | 07:30 PM
1993_EJ1's Avatar
Default Ajustable camber upper control arms problems
has anyone had any problems with egay control arms or even skunk2 control arms? the way the ball joint mounts to the control arm doesnt look too safe to me. would stock upper control arms be better? my car is lowered 1.5" with eibach lowering springs
Old Jan 5, 2011 | 08:50 PM
apexi_rsx's Avatar
Default Re: Ajustable camber upper control arms problems
never had any problem with my BLOX ones. im sure skunk2 would probably be just as good . their designed the same way.As long as u tighten the settings down u wont have any problems.
Old Jan 5, 2011 | 10:09 PM
1993_EJ1's Avatar
my friend gave me a set of control arms. they are the generic kind. first problem i found with them were that the bolt holes for the bushings wasnt lined up. when i put them on the springs hit the control arm, thats why i installed eibach springs. i havent put the control arms back on yet because i didnt know if it would be better to replace with OEM arms or the ones that look like they are from ebay......
Old Jan 5, 2011 | 11:51 PM
evilclown312's Avatar
Had no issues with my blox ones, skunk2 ones are supposed to have better ball joints..
702SI
Suspension & Brakes
May 12, 2017 07:00 AM
kamikazie
10
Jan 10, 2013 08:44 PM
bcrosby51
Jul 24, 2007 11:42 AM
matt1982
Mar 17, 2007 09:45 AM
civiccpedx
Oct 19, 2004 12:49 PM
