B18c1 build questions!
Old Jan 5, 2011 | 02:32 PM
AaronGeisinger's Avatar
Default B18c1 build questions!
I want to get some great strong power out of my b18c1 can u guys give me some info on a good setup motor wise such as Cams, valves, valve seals, crank, pistons, rings, ect... I am going to take the motor and head to a machine shop as well to port and polish the head and instal the valves springs seats and retainers.... i would just like some info on size make ext please! Thank You! Please BUMP if viewed!
Old Jan 5, 2011 | 02:36 PM
b18c8's Avatar
Default Re: B18c1 build questions!
tune get pistons n cams flat valves dual valve springs retainers a bad *** header and intake mani with sum nice injectors it will be a lil beast
Old Jan 5, 2011 | 03:02 PM
I have headers and skunk two intake manifold already and bigger throttle body not sure what size but bigger and what size injectors? 750cc?
Old Jan 5, 2011 | 04:49 PM
b18c8's Avatar
lol 750 to big man i not goin boost u need like 350 at least idk wat u got done to it lmk n ill lyouk
Old Jan 5, 2011 | 06:07 PM
soupE__'s Avatar
p30 pistons and some toda b's lol
What are you trying to get at? Daily driver or what..
Old Jan 5, 2011 | 06:11 PM
well not really daily like nice day get out rip it!!! some track time little bit of it all.... not a race car but eventually put some boost to it.. isnt there a setup that will give me some power and then eventually i can boost it!!
Old Jan 5, 2011 | 06:32 PM
CanadianEF9's Avatar
that is hard to do pretty much you need to make the decision now if you want all motor or turbo unless you want to build all motor now then tear it apart again later and install low comp pistons. you could fully build the motor now for turbo on like 9.7:1 with forged pistons,rods,cams,valve train,etc and it will still be quick on a tune then later on put the turbo on then you just have to pay the extra money to have it tuned again and possibly a different set of cams. just my 2 cents and i hope it helps
Old Jan 5, 2011 | 07:21 PM
N/A's Avatar
N/A
Purpose Built
Originally Posted by b18c8
flat valves
OEM valves are better with N/A setups
You're gonna have to decide if your going NA or FI
If you plan on boosting later just save up for that your gonna spend too much buy and build NA stuff just to rip it apart later to boost it.
I would take a look at R H M T . C O M
You can make a basic setup for cheap and keep upgrading it as you go along.
Or just swap this thread into the FI section here
Old Jan 6, 2011 | 03:08 AM
b18c8's Avatar
you wana boost later u might as well stay like u are just get an intake mani n tb n injectors lightweight flywheel and tune u should be happy lol
Sagara09
Apr 7, 2013 08:26 AM
blade0314
36
Mar 12, 2011 08:25 PM
Powelly
Feb 29, 2008 06:52 AM
madjdmy0
Oct 10, 2005 04:22 PM
pg_thao
Apr 22, 2002 08:44 AM
