93 Dash, Does it seperate top from bottom?
Hey im in the process of getting a new dash in my car. I have to dash's tops bad on one bottom is broken on the other. Is it possible to seperate and combine them? It looks like it would?
I had the same question then went to the junkyard and went at it. The dash is put together in 2 parts at the factory and in the inside of the dash there are screws that hold the top in place. What you can't really see is the glue they use along the seams on the inside. So in theory, I should be possible but in my expierence it isn't worth the effort.
Ok, i ended up just tearing into one, i came to the same conclusion. Its kind of silly if you ask me that its screwed together and partially moves but yet it does not come apart..
Will Albers
Mar 16, 2004 10:08 AM
