The best Integra Type R motor.
Old Jan 3, 2011 | 06:39 PM
Tenassi's Avatar
Icon6 The best Integra Type R motor.
I would like to know which one is the best between them all ? What are the differences between them all ? From 1996 to 2001. USDM or JDM ? Explain if you can. By the way, I have searched but I did not find what I was looking for. Thanks.
Old Jan 3, 2011 | 08:00 PM
racebum's Avatar
Default Re: The best Integra Type R motor.
in short virtually none
there was a cam change in 98 on the intake side that had a basically non existant effect on power. something like 3deg on the intake at 1mm
in jdm land the hand ported heads went to cnc in 98 and the 4-1 jdm header from 98+ is the best of the oem manifolds
jdm pistons also had a slightly larger dome raising the compression to 11:1 from 10:6-1
that's it
usdm itr engines are extremely difficult to find unless you either buy a new one or a bare block from someone. very rarely will you see one in good shape for sale
the 96-97 engine usually sells for $2500 shipped and the 98+ around $300-500 more
Old Jan 4, 2011 | 02:44 AM
Tenassi's Avatar
that's it
Do you have the transmission included at 2500 dollars or if it is just the engine ?
Old Jan 4, 2011 | 02:47 AM
tofu1413's Avatar
usually the whole package goes for 4000+
tranny alone is 1000+
Old Jan 4, 2011 | 08:32 AM
Tenassi's Avatar
Old Jan 4, 2011 | 09:02 AM
ekcoupeh22's Avatar
k20R lol i want that swap so bad!
Old Jan 4, 2011 | 10:23 AM
H-PIMP's Avatar
I'm biased towards the '01 USDM B18C5.
Old Jan 4, 2011 | 01:16 PM
racebum's Avatar
just the engine. if you want a tranny they go around 3500 shipped or 3900-4000 for a 98+
Old Jan 4, 2011 | 03:04 PM
wunfstgsr's Avatar
Loved
Community Favorite
that's it
well said, you can do like me and ditch the mystery used ITR swaps and buy it all new. I built this one with the exception of ARP head studs. remember the head comes pretty bare brand new its missing the v.c vtec solinoid manifold assembly, the block comes completely assembled. Tranny will cost around $1,200+.
Old Jan 4, 2011 | 03:07 PM
ekcoupeh22's Avatar
how much did the block and head cost you??
Old Jan 4, 2011 | 03:16 PM
94eg!'s Avatar
#1 Super Guy
Loved
http://www.acurapartswarehouse.com/P...gPicture=False
You can find them for a little less form dealerships on ebay as well...
Old Jan 4, 2011 | 03:24 PM
Tenassi's Avatar
Too expensive for my wallet.
Old Jan 4, 2011 | 03:27 PM
ekcoupeh22's Avatar
wow i though it would be alot more than that! i might almost consider buying brand new!
Old Jan 4, 2011 | 03:54 PM
wunfstgsr's Avatar
Loved
Community Favorite
pretty much i got the block from ebay from a dealership for $2,500 the head on ebay from another dealer for $1,500 and the tranny new from a guy here for $1,500, the v.c and v.c gasket,head gasket set was seperate the clutch kit was extra, the manifold i found used complete for around $200, the 98 usdm ecu cost me $550 the intake arm cost me $40 and all the rest of the little things like misc bolts vtec solinoid ect i had from my swap i sold.
https://honda-tech.com/forums/showth...2556604&page=5
Old Jan 4, 2011 | 05:37 PM
PaulMc's Avatar
Painfully Stupid
Very impressive. Great way to spend that kind of money. I guess the cheaper route would be to just have an OEM rebuild on the stock motor. I'm glad to know Honda still makes the parts like this.
Old Jan 4, 2011 | 05:40 PM
ekcoupeh22's Avatar
thats not bad thats only about 1500 more than a used jdm swap
Old Jan 4, 2011 | 07:07 PM
wunfstgsr's Avatar
Loved
Community Favorite
i spent more than $6,000 on just the motor and trans. and still needed little things... its expensive but if you can assemble a motor and dont want a rebuilt motor its the way yto go!, i hated how every built motor i had burned oil pretty much eventually but this one is great!
https://honda-tech.com/forums/acura-integra-type-r-8/breaking-itr-motor-dealer-2736772/
Old Jan 4, 2011 | 07:18 PM
ekcoupeh22's Avatar
i think i might consider this!
Old Jan 4, 2011 | 10:49 PM
HYREV2NR's Avatar
Me too, being that I own one. That's dead at the moment.
Old Jan 4, 2011 | 11:39 PM
racebum's Avatar
rebuilds aren't what they are cracked up to be in a lot of cases. these engines have cylinder liners that shift and mains that can distort. it's really common to do a rebuild and have an oil burner.
personally if you want a DD for mileage i would either go jdm or new
jdm has one advantage in that you get it all
new has an advantage in it being just that, new, that's 150k miles or so you'll personally get
if you do go new. don't sell the fkknifdawing car ! it's going to be a trouble free DD for at least a decade
Old Jan 5, 2011 | 12:21 AM
Hyoriu's Avatar
If you want to get into specifics about the ITR motor, here's a pretty good thread.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/usdm-vs-jdm-itr-2811558/
....I think....please don't flame me >.<
Old Jan 5, 2011 | 03:49 AM
pablosd's Avatar
ITR's didnt get that upgraded cam till 99-00 RX model
CTR's always had it since being introduced in 97
think 96spec engines were hand assembled opposed to 98spec engines being machine assembled, dont qoute me on that as im not entirely sure bout it, think it was mentioned on Best Motoring comparisment between 96 vs 98 spec
Old Jan 5, 2011 | 05:58 AM
GHILD77's Avatar
Same here
Old Jan 5, 2011 | 09:49 AM
HYREV2NR's Avatar
Originally Posted by GHILD77
Same here
So whats the story? Mine was a bad tune with a SC, too much timing goesBack on topic, I believe a lot of oil burning on a rebuilt motor is improper piston to wall clearance along with bad ring gap.
Old Jan 5, 2011 | 01:11 PM
racebum's Avatar
as far as i know they were all hand assembled. it's the heads that went from being hand blended to cnc'd
the cam upgrade is kind of laughable. there was a minor 3deg@1mm change on the intake cam, but, my guess is honda did it to save money. why grind two cams when one works? they just went with the larger or the two
