B18c1 Swap not starting
Old Jan 3, 2011 | 06:17 PM
doosua's Avatar
Icon2 B18c1 Swap not starting
Hey guys, I done as much research as i can before i posted.
I swapped in a 97 b18c1 into my 2000 EJ6 Hatch and the engine cranks but no fuel? I pulled the fuel line going to the fuel rail and nothing. I had thought that my Main Fuel Relay had been fried so I bought another used Main Fuel Pump Relay *guaranteed to work* and still nothing. I turn the key half way and I dont hear the fuel being pumped or primed for the 2-3 seconds. I also dont see the engine check light come on for the 2-3 seconds also. So now im confused. I checked all my grounds and tightened them too. So any help or suggestions will at least get me somewhere.
Thanks
Old Jan 3, 2011 | 06:44 PM
ej1916's Avatar
Default Re: B18c1 Swap not starting
You check all the fuses? Same thing happened to my stock D16z6, overlooked a fuse and wasted money on a relay. Rechecked and it happened to be a blown fuse I overlooked.
Old Jan 3, 2011 | 06:52 PM
doosua's Avatar
How do you know that a fuse is blown?
Old Jan 3, 2011 | 08:03 PM
luvmihatch's Avatar
pull it out look at it and u will see the bridge broken. or get a fuse tester
Old Jan 3, 2011 | 08:09 PM
hon2984's Avatar
re check your ground at the thermostat housing it will disable the fuel system!
Old Jan 8, 2011 | 09:30 AM
doosua's Avatar
Well i re-tightened the ground at the thermostat housing. Im thinking is it because of the little rust on the bolt? Im still on the same problem I also checked both Fuel Relay fuse still no fuel.
Old Jan 8, 2011 | 01:20 PM
D3vin's Avatar
Did you wipe the surfaces of the grounds/grounding area? It could be the rust on the bolt, try changing it out and see. Also, might be a stupid question, but do you have a kill switch to your fuel pump? Cuz I forgot to turn on the switch when I put in my swap. LOL
Old Jan 8, 2011 | 01:26 PM
94dxcoupe's Avatar
... Also don't forget ground on the valve cover to radiator support/ body panel
Old Jan 8, 2011 | 02:19 PM
doosua's Avatar
Yeah i wiped it. Im thinking of getting new bolts. But i dontk now what a kill switch is. I know i have spark. I just dont know why im not getting any power to my pump.
gs-r94coupe
Oct 30, 2010 03:35 PM
97booger
12
Sep 17, 2009 12:35 AM
GSR-TRBO-DA
Jul 6, 2007 01:29 PM
90AcuraIntegra04
Jan 6, 2006 05:41 PM
91civicmoneypit
10
Feb 24, 2005 11:11 PM
