B18c1 Swap not starting
Hey guys, I done as much research as i can before i posted.
I swapped in a 97 b18c1 into my 2000 EJ6 Hatch and the engine cranks but no fuel? I pulled the fuel line going to the fuel rail and nothing. I had thought that my Main Fuel Relay had been fried so I bought another used Main Fuel Pump Relay *guaranteed to work* and still nothing. I turn the key half way and I dont hear the fuel being pumped or primed for the 2-3 seconds. I also dont see the engine check light come on for the 2-3 seconds also. So now im confused. I checked all my grounds and tightened them too. So any help or suggestions will at least get me somewhere.
Thanks
Thanks
Re: B18c1 Swap not starting
You check all the fuses? Same thing happened to my stock D16z6, overlooked a fuse and wasted money on a relay. Rechecked and it happened to be a blown fuse I overlooked.
Well i re-tightened the ground at the thermostat housing. Im thinking is it because of the little rust on the bolt? Im still on the same problem I also checked both Fuel Relay fuse still no fuel.
Did you wipe the surfaces of the grounds/grounding area? It could be the rust on the bolt, try changing it out and see. Also, might be a stupid question, but do you have a kill switch to your fuel pump? Cuz I forgot to turn on the switch when I put in my swap. LOL
Yeah i wiped it. Im thinking of getting new bolts. But i dontk now what a kill switch is. I know i have spark. I just dont know why im not getting any power to my pump.
