Fuel Pump gone out?
Old Jan 3, 2011 | 02:35 PM
90Accord Man's Avatar
Default Fuel Pump gone out?
I have a 90 accord ex and recently my car won't start. I have reason to believe that the fuel pump has gone out completely. Before when it did run, sometimes it wouldn't start for some unknown reason. i noticed that i heard a sound go (like a pump or something) on whenever it would/could start and i wouldn't hear the same sound if it couldn't start and now the car does not have the sound completely and my car is a nice paper weight in my driveway..thinking its the fuel pump? maybe other problems with it too? ive had idle problems also such as low idle. Anyways if anyone can give me insight or ways to fix sed problem it would be greatly appreciated.
Old Jan 3, 2011 | 05:47 PM
94EG8's Avatar
Seagull Management
Default Re: Fuel Pump gone out?
Main relay is probably bad. Honda fuel pumps almost never go bad.
Old Jan 8, 2011 | 11:31 AM
CL63-CB7-AMG's Avatar
I had the same problem today with my 92 honda accord. I took the Main Relay out of my 92 Honda accord (#1) and swapped relays with accord (#2) and the car started right up. So I took the bad relay and plugged it to the running car and it did not start. Car cranked and I got spark but didn't run.
I can't say that I fixed the problem that caused it to go out. But I at least got the car running.
Im about to attempt to repair non-working Main Relay and ill post results if relay becomes fixable.
Old Jan 8, 2011 | 12:01 PM
Im back and with great news.
I took apart the main relay. and the solder on two post were cracked.
I removed all the old solder and place new solder down. plugged the main relay back in. and the car is runnin. I plugged both relays back into both cars to make sure and both cars are running fine. You dont have to replace your relay just fix it if you can.
Old Jan 8, 2011 | 02:54 PM
nus_dogg's Avatar
Glad you got it fixed.
Old Jan 15, 2011 | 02:54 AM
thanks guys ill check the relay as soon as i can and update what happened.
Old Jan 15, 2011 | 04:34 AM
andyz's Avatar
Tap the relay while starting.
Old Jan 16, 2011 | 02:13 PM
for some reason i cant find my main relay under the dash fusebox on the left side. can someone put a link or pic as to where it is
Old Jan 16, 2011 | 02:54 PM
wait nevermind i got it out, anyone know the easiest way to pull the relay out of the case?
James Olmstead
May 21, 2012 07:26 PM
WaYtOoLoW
Feb 24, 2010 06:30 PM
raylightt
Sep 7, 2008 08:14 PM
JBMINI
Jul 15, 2006 05:20 AM
spettinger
May 25, 2005 11:46 AM
