98 accord low compresion
i only have 70 psi on cyl no 3 any suggestions on chemicals to pour in cyl to see if ring will break loose if just by chance i have a stuck ring.sea foam?let stand for a day or so?
if ring is truly stuck/broken then the cylinder wall is toast. Are you burning oil? If not then try checking intake and exhaust valves. Bring #3 to TDC compression stroke and pull valve cover. Check rocker arms on #3. They should all have a little play in them. If not then that valve is not fully closed. Could be fixed with valve adjustment.
checked rocker ars had a .005 gap on int and .007 on exh gonna go deeper tmorrow will have head off and oil pan thursday might as well do a bottom end
ok guys need some help here i need a breakdown of the bottom end of this thing 1998 2.3 vtech need illustartions on complete bottom end with some torque specs any help will be greatly appreciated
The haynes manual has all the torque specs. Only 10-15 bucks at autozone. Has pics of crank and all.
Never rebuilt a 2.3L though. Since you had clearance on all your valves then the only other place to lose compression is pistons. Unless the valves seats are totally gummed up and leaking even at TDC. You'll know when you take the head off.
Took head off checked ring gap close to being too wide.oil rings stuck.valves have blowby.as in put fluid in exhaust ports and leaked through valves are not seating took to machine shop
mitsuman
21
Oct 4, 2006 08:50 PM
