idle jumping on my d15b8
Old Jan 2, 2011 | 08:29 PM
EusebioSam19's Avatar
Default idle jumping on my d15b8
my idle jumps on my d15b8 on my civic
im running a auto p28 on it. the p05 i had took a ****
and i got this for cheap.
but sometimes itll just stop but still run at a high idle like 1500 rpm
i checked my IACV and cleaned it.
help
Old Jan 2, 2011 | 09:14 PM
Former User's Avatar
Default Re: idle jumping on my d15b8
Any CEL codes?
Have you cleaned and adjusted the FITV?
Old Jan 6, 2011 | 10:51 AM
mrbassman001's Avatar
Originally Posted by RonJ@HT
Any CEL codes?
^^x2^^
Old Jan 6, 2011 | 12:39 PM
dfJDM's Avatar
Originally Posted by mrbassman001
^^x2^^
^^X3^^ had the same issue, clean out the fitv and check all your vac lines.
Old Jan 8, 2011 | 01:14 PM
I was lookin around on my car and I don't think my b8 has it I cleaned my throttle body and the Iavc nothin you know wack comin to a stop at a light having your car sound like it has asthma
Old Jan 8, 2011 | 03:00 PM
Don't make helping you difficult. Any CEL codes? A stock b8 has a FITV attached to the bottom of the throttle body.
Old Jan 10, 2011 | 06:27 PM
I have some pics I need to post up I took my throttle body off, im like 99.9% I don't have an fitv theirs just 2 hoses that run through.I was thinking maybe my tps? I am running an auto p28 some I'm getting the usual solenoid lockup cel but that's just cause I haven't converted the ecu to 5 speed. Is the fuel distribution different since I'm running the ex/si d16z6's ecu on my d15b8. When the idle maintains at 1k cause sometimes it'll just stop jumping and stay at 1k-1100k rpm and you hear like a little sputtering I'n the exhaust kinda like a low "pa paa paa pa..."
Old Jan 10, 2011 | 06:52 PM
wheelmanbg's Avatar
how's your timing?
that_boy_sammy
15
Nov 23, 2009 12:15 PM
mister.wong
29
Mar 10, 2009 03:24 PM
sevendurt
Jun 5, 2008 03:52 PM
924doorEG
Nov 19, 2007 08:15 AM
924doorEG
16
Nov 15, 2007 06:14 AM
