Tranny Problem??
Old Jan 2, 2011 | 02:27 PM
ari_one's Avatar
Default Tranny Problem??
Hello all, new here but looking for a little input. Helped a friend put in a new clutch in his 91 CRX 5sp, all stock. Ended up doing the rear main seal, oil pan gasket, lower ball joints and a new axle at the same time. Tested after we were done and all seemed ok. When he took off just a couple of hundred yards later he said he heard a "pop" and no gears! When in neutral no sounds, when trying gears 1-4 nothing, 5th makes noise. Turned car off, put it in neutral and pushed it and it gives a loud 'thud' or 'clank' about each rotation of the wheels.
Thoughts?
thanks in advance.
Old Jan 2, 2011 | 06:04 PM
hatchet_honda's Avatar
Default Re: Tranny Problem??
check to see if the axles are seated properly. if ones popped out you wont move. if thats not it then the trans exploded
Old Jan 3, 2011 | 07:41 AM
josephcmiller2's Avatar
Axles not all the way in. I'd bet $20. I've had it happen more than once on mine and it does feel like busted clutch at first.
Old Jan 4, 2011 | 06:26 PM
ari_one's Avatar
The axle had not slipped out but instead the new re-manufactured axle had come apart at the wheel. Looks like the joint came apart and then tore the boot off. Got a new axle and all is well.
Thanks for the input.
Old Jan 5, 2011 | 10:18 AM
mr2krash's Avatar
brand new axle came apart at the wheels? Were you using the right size/model/year......if you have too short an axle, one tight corner and you'll be back in the same spot again
jimmy o.
Mar 13, 2010 04:22 PM
mingbling96
Mar 13, 2005 08:14 AM
FormulaGSR
Oct 5, 2004 04:34 PM
white95eg
May 20, 2004 06:10 AM
leadfoot78
May 26, 2003 12:17 PM
