95 civic ex wipers only work on high?
Old Jan 2, 2011 | 12:34 PM
Silversubie's Avatar
Default 95 civic ex wipers only work on high?
Hey everyone, I got another issue. My wipers only work on high but every once in awhile the low and intermittent start to work. Is it a switch going bad?
Old Jan 2, 2011 | 01:33 PM
4dregDC's Avatar
Default Re: 95 civic ex wipers only work on high?
Seems like switch might be goin bad
Old Jan 2, 2011 | 01:37 PM
Linked's Avatar
the moving contact points inside the wiper switch tend to get worn out over time,
some have taken them apart and cleaned the contact points and relubed
some have bought new from the dealer
but your switch is most likely the culprit
Old Jan 5, 2011 | 10:48 AM
Switch being the arm that comes out of the steering column?
Old Jan 5, 2011 | 10:52 AM
Former User's Avatar
Check the FAQ sticky for the DIY for cleaning the switch contact points.
The wipers have a high- and low-speed motor. You could run power and ground wires directly from the battery to the wiper low-speed motor to see whether it works.
bluelights81
Dec 25, 2013 08:04 PM
dirtridernathan
12
Jun 29, 2013 10:32 AM
SR20 Inside
Jan 25, 2006 09:24 PM
ferio 95
Mar 3, 2005 04:47 AM
limegrnxj
Mar 21, 2003 08:57 AM
