what happens when you mix ls waterpump and type r belt
Old Jan 2, 2011 | 09:13 AM
just-ef-it's Avatar
Default what happens when you mix ls waterpump and type r belt
k, for the record,
i know you use a ls waterpump with a ls belt
and you use a typeR/gsr/ vtec waterpump with the matching belt
i got that lol
but what happens if you mix them?
how will the motor run?
has anyone ever made this mistake? lol
Old Jan 2, 2011 | 01:56 PM
stackedhouse's Avatar
Default Re: what happens when you mix ls waterpump and type r belt
not quite sure but if the teeth are different the timing will be affected
Old Jan 2, 2011 | 06:06 PM
hatchet_honda's Avatar
timing will be off. ls pump has diff teeth count sooo thats why you dont use it
Old Jan 2, 2011 | 06:59 PM
j3wman's Avatar
the reason is the pump goes too quick and you get bubbles in the coolant doesnt effect timing tho
Old Jan 3, 2011 | 07:36 AM
josephcmiller2's Avatar
Timing won't be affected. When you time your engine, you don't line up your water pump. You can't mix the ls water pump and type r belt because the belt is too long and you won't get proper tension on it, if any at all. The ls water pump has a smaller gear than the VTEC water pumps.
Old Jan 4, 2011 | 09:24 AM
just-ef-it's Avatar
k, thanks guys
thats pretty much along the same lines as what i thought too!
Justintegra
Apr 20, 2008 12:46 PM
lsvtechatch04
May 8, 2004 03:20 AM
JR Integra
May 3, 2004 04:17 PM
vtecb20coupe
Dec 10, 2003 12:15 PM
275Performance
Jan 4, 2003 04:45 PM
