Can Vtec set to open 2 time with CROME
Hi, is that true some car open vtec 2 time, i look at b18c last night, the sound look like vtec engage 2 time. It is possible using crome advance vtec switchover or Plugin - control - Control Advance Vtec setup P28,P30,P72 to make vtec open 2 time.
I have my vtec kick in 6 times each pass on my 8 second integra using crome :-)... Just kidding.
As JR stated, the b18c1 engine has ONE vtec lobe, hence vtec is at one activation point.
The intake air butterfly system (IAB) is on the stock b18c1 engine & h22 engines. This is an output which will open the runners in the stock manifold at a specified rpm.
May also what to do some more reading on how VTEC works. IIRC once VTEC is engaged it stays engaged until your drop back down below the engagement parameters.
Yeah i will
, reading searching and looking in youtube bout vtec and IAB work. Thank for the hint. And I'm dont want to add IAB to b16, I just want to know why b16 sound like 2 vtec engagement, is there possible they put Iab system to b16 engine. I think maybe i got wrong hearing or that car vtec system is broken..hm * Start reading!!!
That could also have to do with the design of the engine components. For example, my F22B2 non VTEC sounded like it had VTEC @ around 3800-4200 RPM. That was after I added 255cc injectors, headers, ported intake manifold and a short ram intake. I am going to assume that that was where everything clicked together and there was a power band change. Never had it on a dyno so I cannot confirm actual power gains, this was just an ear and butt dyno assumption. Not just mine ether
Looking into old thread, https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/difference-between-vtec-switchover-vtec-engagement-2632906/
In the B18C1 I am pretty sure that there are only two cam profiles, the low profile lobes that are used when VTEC is not engaged and teh high profile lobes that are used when VTEC is engaged. So I am not quite sure what you mean by "secondary lobes," "primary lobes," and "VTEC lobes." :-p
so that explain me a lot, hm it maybe not a vtec open 2 time at all..
Looking into old thread, https://honda-tech.com/forums/showthread.php?t=2632906
Correct me if wrong, Low Cam table run when vtec Off, and High Cam table run when vtec On. And what used for < C R O M E > advance table - vtec switchover since there have table to adjust Low Load [Engage/Disangage] and High Load [Engage/Disangage] it is different thing between Low cam @ Low load / High cam @ High load? here i attach the picture.
Disengagement RPM is exactly that: what rpm at which VTEC will disengage and allow the rockers to return to the low speed cam lobes.
The only engines that have "two stages of VTEC" are certain JDM D series engine from 96-00 IIRC
This is not VTEC engaging twice. The picture shows CROME'S 'attempt' at variable engine load (ie: map values) to allow VTEC to engage slightly earlier or later dependent on engine load...
So no such thing vtec open twice except D series engine 96-00 IIRC like you said. There lot of local chip seller lie on vtec open twice in the internet..so i will not get cheat with all answer in here. Thanks
http://causeforalarm.thecarthing.com...TEC/index.html
civickid03
Mar 25, 2004 11:00 AM
hahaha
