Is it possible to run a eg/dc subframe in a ek with a b-series?
I have a ek with a b-series and I would like to know if I can run a eg/dc subframe and rack with the rear t-bracket? Reason why I want to do this is quaifie only makes the steering quickener for eg/dc manual rack. also would I run the eg front lower control arm or ek?
i know the eg/dc subframe will fit on a ek with a kswap but i need to know if it works with a b swap and whats needed?
I would think just a Eg/Dc T bracket, and are the rear mounts the same for 92-00?
You also will need to run all of the Eg/Dc Complinace bushing hard ware/bushing. Basicly everything compliance bushing related, but yes you can run either control arm.
. Or just run the Eg/Dc LCA.
thanks for the info^ but has anybody actually done it? i need a definite yes before i start getting everything.
there was a post about puting the dc steering rack pinon on an ek rack to quicken the steering. http://https://honda-tech.com/forums...%26quot%3Brack maybe try that.
already have that ^. problem is the dc pinion gears are finer than the ek rack and it wears out the teeth over time. also i would have to run a breather for that setup. i rather just run a eg manual rack.
up lets see if anybody has done this i know there has to be somebody.
sk8shorty012
31
Mar 9, 2011 10:24 AM
