B18c1 Cannot Zero into TDC Ignition Timing
So I installed a set of adjustable cam gears into my swap. The gears are at 0 atm and point UP when at TDC. The problem I have is when I adjust the ignition timing via distributor, I can't zero into TDC. My dist is all the way advanced and can't go any furthur.
