ej1 b20 swap, crank but no spark or fuel pressure...HELP!!!!!
Old Dec 31, 2010 | 12:29 PM
gsr_sleeper916's Avatar
Icon2 ej1 b20 swap, crank but no spark or fuel pressure...HELP!!!!!
ok so i got a ej1 b20 swap no spark so i changed dizzy, fuel pump, and just changed my ecu and still no spark or fuel pressure...im stuck and dont know wat to do!!! my cousin said i got an electrical problem but i dont know where to start?
Old Dec 31, 2010 | 04:58 PM
93blackcivic's Avatar
Default Re: ej1 b20 swap, crank but no spark or fuel pressure...HELP!!!!!
Eh start trouble shooting and make sure you have power at all points
igniter
coil
ecu
Make sure you check to make sure your fuel pump is priming when you switch the ignition.
Get a test light!
Check all fuses because static can blow one anywhere
I forgot: I hope you already verified that the ignition switch is good, and the starter and the fuses under the hood
Or Go here and go step by step because you hate googling
http://techauto.awardspace.com/ignition.html#flowchart
Old Dec 31, 2010 | 04:59 PM
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2Apost-links-helpful-faqs-so-we-can-get-archive-going%2A%2A%2A-642479/
http://www.diymyhonda.com/integra/in...s-valve-seals/
TIMING IS EVERYTHING
attia
Oct 30, 2014 04:41 AM
Turbob22crx
Dec 4, 2012 07:16 AM
ha...tch
Jun 11, 2008 06:36 AM
b20integrapower
Oct 17, 2006 03:43 PM
jdmfun99
18
Apr 24, 2005 06:41 PM
