How important is it to have matching final drive and ring gear.
Hey HT
How important that i keep the gsr ginal drive with a gsr ring gear. I have a gsr gear set and a lsd with a "b16" ring gear. I counted the teeth on both and theyre 66 on each. Noob here.
you cannot use the 14 bolt pattern lsd with any other ring gear except the one you have on it. i would, however, consider comparing your series b16 transmission ring gear with any other year model transmission and see what(or which) one was exact or closest to your transmission ring gear as well as use that countershaft(or final drive) as your new matching part.
Thanks
R.A.T.
Transmission & Drivetrain
11
Dec 14, 2009 04:33 PM
