P0740 check engine light problem
I have the check engine light. P0740 tcc circuit malfunction. What can I check to fix this I tried everything I can think of? Nothing is wrong with the transmission it shifts with no problem and the fluid is full and fresh genuine Honda tranny fluid. I reset ecu and PCM by removing thE fuse for it and it went off then I went 55mph and stayed for few minuutes and it came on it's done this a few times all at 55mph. Please help. Thank you
I have the check engine light. P0740 tcc circuit malfunction. What can I check to fix this I tried everything I can think of? Nothing is wrong with the transmission it shifts with no problem and the fluid is full and fresh genuine Honda tranny fluid. I reset ecu and PCM by removing thE fuse for it and it went off then I went 55mph and stayed at 55mph for few minuutes and it came on it's done this a few times all at 55mph. Please help. TY
I changed the top solenoid I think its the lockup solenoid.
I have a d16y8 head with a d16y7 block could this have anything to do with it?
The transmission was just changed the old one had gear problems, they were slipping.
1998 honda civic ex automatic
Please carefully read the diagram.
-Have you checked for additional codes that blink from the D4 light when the service connector is jumped?
-Have you checked the line pressure?
hey, first i checked the solenoid and heard the clicking i did that diagnostics. Also i did the service connecter thing and both the d4 light and the check engine light was blinking. the ecu reads p0740 and p0700. me and my mechanic dont have these guages, what do i do next?
ice4me
Nov 30, 2006 01:36 PM
pang07
Jan 7, 2005 05:12 PM
