help with gauge cluster lighting
Old Dec 27, 2010 | 08:13 PM
Tylerb18's Avatar
Default help with gauge cluster lighting
so i have been fooling around with my gauge cluster because it was flickering on and off.. finally it just stopped working all together ( the backlights that is) the bright's lights check engine lights battery lights ect ect would all light up when needed, the car was converted from auto to manual befor i bought the car and the automatic gauge cluster i have works for it the back light and all the other lights do atleast.. but then if i want to run one of those in the car the only gauge that works is the fuel gauge.. -.- so i kinda have a delema here.. id like to run the manual cluster but i also want the lighting to work lol.. if anyone can help me ASAP it would be greatly appreciated thanks much.. - Tyler
Old Dec 27, 2010 | 08:20 PM
wheelmanbg's Avatar
Default Re: help with gauge cluster lighting
What works and what doesn't???
If you're having problems with the backlighting, check your dimmer switch
Old Dec 27, 2010 | 08:24 PM
Tylerb18's Avatar
well see there are a few things that work on the manual cluster (which is what id like to have in the car..) those being the guages and all the indicator lights.. but no blacklighting. I replaced all the bulbs, and fuse's. It's not the dimmer switch because i have it ran threw a flip switch so its at its brightest at all time, (cheap 5 dollar fix for insted of getting a new dimmer switch :D ) .. but when i put in the automatic cluster then the backlighting works along with all the indicator's but none of the guages work
Old Dec 27, 2010 | 08:29 PM
wheelmanbg's Avatar
Looks at the back of the manual cluster and see if you notice any burnt lines in the circuit board. Sounds to me like you need a new cluster.
Old Dec 27, 2010 | 08:49 PM
Tylerb18's Avatar
thats most likely it ill try getting one from a friend to see if theres work. any chance you would know why my radio settings and my clock settings dont save either :D?
Old Dec 28, 2010 | 06:15 AM
Former User's Avatar
Check whether the 7.5A Back Up fuse in the hood fuse box is blown.
Sprockets
Apr 28, 2016 05:12 PM
judd_123
Lighting
Feb 8, 2010 04:25 PM
