I have to pump the gas to start the car WHY?
Ok I have a 96 accord the (always on) cel is on I use 93 gas. Ok I notice this porblem after the cel. Lastweek I put 100 octain in the gas thank I put 3gal on top of the 93 which I was lil bit below the full mark. I drove the gas out to half tank put back 100 octaine fill it up to full so is was still mix i was at 98 octain. From that next day car couldn't start I change the spark plug car won't start so I had to pump the gas and it start. I drove out the gas to E. I put a quater tank of 94 and still getting the problem why is this.
You should retrieve the CEL code(s) that are stored on your ECU. It/they could tell you exactly what is wrong. Or at least steer you in the right direction.
If you are mechanically inclined you could do the paper clip trick to retrieve the CEL codes yourself. Here is a link for more info on Self diagnostics https://honda-tech.com/forums/showth...ght=diagnostic
Tell me it's an H22 to be running 93 OCT?
I highly suggest not running Premium on a stock F22 unless it's High Compression. You'll really mess up your motor by doing that. It won't give you hp in anyway. 87 will detonate before 93 OCT; thats all it does is an anti-knock.
87 will do just perfectly fine with a 8.8:1 CR unless you're 10:1 and up like an H22.
Doesn't mind burning money out the tail pipe?
http://video.answers.com/the-best-oc...-car-155905288
DangercartSi
May 24, 2024 09:07 PM
xprest1ge
Apr 21, 2019 12:02 PM
eg6king!!!
Jan 27, 2012 01:39 PM
