NSX Caliper on ITR (Quick Question)
I know this topic has been beat to death but I have some quick questions if someone can help, I am doing the ITR 5 lug convo on my 99 GSR, and I am looking into the NSX caliper upgrade.
I AM using 15 inch stock ITR wheels, so I have two questions.
I know I need to buy the NSX caliper and bracket, but can I use the stock ITR rotor I have? Or should I upgrade to a NSX or Legend rotor?
Do I have to use the pre 96 NSX calipers to fit in a 15 inch wheel? I heard that the 96+ does not fit in anything smaller than a 16 inch wheel.
Thanks guys!
Thanks guys!
a. I know I need to buy the NSX caliper and bracket, but can I use the stock ITR rotor I have? Or should I upgrade to a NSX or Legend rotor?
you must use the bracket associated with the rotor.
the 23T is meant for a rotor which is 23mm thick (oem ITR, prelude VTEC).
the number on the bracket (ie., 23T, 25T or 28T) determines the size of the rotor it will accept in millimeters.
the issue is the clearance of the hanger and offset of the rotor.
1. ITR 23mm rotor, use the 23T bracket
2. NSX 28mm rotor, use the 28T bracket
*for reference, check out pics in the link below*
Originally Posted by Charlie Moua:
http://www.hondamarketplace.com/show....php?t=2665842
NA1 & NA2 NSX front calipers have:
1. different size pistons sizes
2. different brackets (NA1 vs NA2)
3. brackets interchangeable
15" oem wheels = NA1 or NA2 calipers + 23T brackets + 11" 23mm rotors (oem ITR)
16CL15VN
Product Code: FB DA/DC/SI REAR NSX 11
Fastbrakes designed 11" rear brake kit using the NSX calipers for the Integra or Civic with rear disc brakes.
Kit comes with the 11" plain rotors and the adapter kit, CUSTOMER MUST PROVIDE CALIPERS AND PADS.
Uses calipers from 1992-1996 NSX.
List Price: $320.00
Our Price: $320.00
Sale Price: $320.00
http://www.Fastbrakes.com/product_p/...20nsx%2011.htm
14CLP15V
2.) All NSX calipers have the same overall dimensions. Only the piston size changed between the 96 - 97 model year. The brackets also changed, but that doesn't effect you since you're using ITR rotors. For example, I'm using 97-05 NSX calipers with the smaller 11.1" diameter, 25mm width rotors from a '97 Acura 3.0CL.
yes, you can use the 15" oem ITR wheels (on your 5-lug conversion) with stock ITR front rotor with NSX calipers if you use the ITR's 23T bracket.
fastbrakes.com
List Price: $320.00
Our Price: $320.00
Sale Price: $320.00
14CLP15V
List Price: $320.00
Our Price: $320.00
Sale Price: $320.00
14CLP15V
that's nice, BUT why clutter this thread?
let's stay on topic here:
the OP needs info on
1. rotor set-up for NA1/NA2 front calipers on his 5X114.3 knuckle/hub on oem ITR 15" wheels
2. rear NSX calipers on 5X114.3 ITR rear trailing arm
what? yo stop posting mis-information smh
negative...the NSX rear calipers (stamped 14CLP15V) will NOT bolt-on to the rear ITR caliper brackets
when you tally up all the costs of obtaining:
the NSX rear caliper & pads
fastbrakes kit, adapter bracket & 11" rear rotors
$320 (plus s&h)
Pic Originally Posted by Type Zero,
pictures never lie, from left to right:
a. 7CLP13S - 90-01 integra/civic rear caliper/ 9.4" rotor
b. 9CLP14S - ITR/RSX rear caliper/ 10.2" rotor
c. 14CLP15V - NSX rear caliper/11" rotor
the NSX rear calipers will not bolt-on without a custom adapter bracket & 11" NSX rear rotor
NSX rear calipers on ITR 5-lug
https://honda-tech.com/forums/acura-integra-type-r-8/rear-brake-upgrade-my-type-r-2836406/
imo, the NSX front calipers/11" rotor/23T bracket + stock ITR rear calipers/10.2" rotor
(5X114.3 trailing arm) are more than adequate and functional
there's not a whole lot of info or feedback out there for the 11" NSX rear caliper swap.
the NSX 11" rear set-up is really meant to balance out any front bias from 11.8" front rotors & larger BBKs.
keep in mind, the all four NSX calipers set-up all around on an NSX was designed for a mid-engine RWD;
while a NSX front & back on our front mount engine FWD integra/civic, might create some rear bias
(although it has never stopped me or anyone else from trying)
i dont have any specs on hand, not 100% sure of the rear 11" NSX calipers' offset (with the adapter bracket) in relation to the oem ITR wheels. if it is an issue once it's installed; most likely, this can be easily remedied with spacers
from left to right:
again, the NSX rear caliper is NOT a bolt-on, it requires a custom bracket.
NSX rear calipers on ITR 5-lug: https://honda-tech.com/forums/showthread.php?t=2836406
Ok I think i got everything I need, thanks again, would you say this is worth it vs a real big brake it or a stock ITR setup? I'm doing it more for looks than anything not gonna track the car, but I'm trying to see if the cost will make sense. I can't find a rear big brake kit for 5 lug anyway.
here are the facts:
1. 94-01 integra (regardless if LS, RS GS, GSR) in 4X100 comes equipped with 10.3" front brakes & 9.4" rear disc brakes
2. the ITR 5-lug (in 5X114.3) comes from the factory with 11" front brakes & 10.2" rear brakes. the ITR's front & rear caliper pistons are larger than the integra caliper pistons
3. aftermarket set-ups
a. such as wilwood, spoon, stoptech, mugen, brembo
b. adapter brackets (ie., aem, fastbrakes.com, etc) to keep stock calipers on custom rotors, etc
keep in mind, upgrading calipers will increase your rotor size plus add weight
increasing unsprung weight raises the load placed on controlling the motion of the wheels and tires during acceleration
if you're not tracking the car, dont bother; you wont see their full benefit unless you're on a track.
it seems like a lot of money for some bling, the only difference you will feel is better modulation which is pedal feel.
unless you track your car often you wouldnt notice
for the purposes of daily driving:
the brakes on your 99 integra GSR's brake system are more than adequate
your 99 integra GSR brakes would benefit from a quick inspection & fresh parts.
you might want to consider:
good set of pads,
new blank rotors,
some grease,
fresh brake fluid & tires.
Quote:
Originally Posted by BrakeExpert,
"Your car will only stop as fast as your tires will allow. All the braking in the world wont work if your tires are bald and on ice!!"
Thanks dude ur answers are really well written! Right now on the GS-R I have brembo rotors from and back drilled with hawk pads and its amazing stopping power! I love it, like I said the only upgrade reason is 5 lug for looks and wheels and NSX for purely looks. I know its all the wrong reason to do it but I just want something nice, in case in a couple of years I want to track the car.
...lol
vanity is my favorite sin
if everyone had it, no one would want it;
if no one had it, everyone would want it
