steering wheel removal
Old Dec 24, 2010 | 07:59 PM
thebluecrx's Avatar
Default steering wheel removal
can any one give exact step by step instructions on how to remove the stock steering wheel and replace it with a after market one? the car is a 1989 crx si
Old Dec 24, 2010 | 08:08 PM
Charl3Brwn's Avatar
Default Re: steering wheel removal
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/faq-how-remove-crx-civic-steering-wheel-735808/
Old Dec 24, 2010 | 08:55 PM
asianflava's Avatar
Pop the "H" off and unscrew the nut. No "How To" needed.
Old Dec 24, 2010 | 09:00 PM
KINGVEM^^ED6's Avatar
h in the centerbremove with small flat head
extension.with a 19mm on it
Good to go
Old Dec 25, 2010 | 08:20 AM
thebluecrx's Avatar
i know how to take the wheel i need to know how to put the new one on its a after market RS type wheel i have the adapter and everything
Old Dec 25, 2010 | 04:03 PM
Marcos Barrios's Avatar
well once you take you wheel off the adaptor you have should slide into the bolt you took your old steering wheel off of
before you just slide it in make sure it's nice and straight
put the nut back on nice and tight put your steering wheel on with the 6 alenn bolts and your finished
if you have any other questions feel free to ask
Old Dec 25, 2010 | 07:42 PM
thebluecrx's Avatar
i got it figured out guys thanks the adapter came with a bunch of extra parts so i wasnt sure what was going on
Old Dec 25, 2010 | 07:47 PM
sanchoem1's Avatar
Yeah that can be a bit confusing when you get 2 or 3 different styles of fasteners for one wheel. How do you like the new wheel? When I went from stock to aftermarket I loved it!
Old Dec 26, 2010 | 02:44 PM
thebluecrx's Avatar
this isnt my first aftermarket wheel i had to get a new one because i bent the stock wheel when my timing belt broke hahaha. its just a cheap no name ebay wheel but it is amazing
Mr.CRXsi
Aug 21, 2010 10:06 PM
dustin_crxsi
Oct 30, 2006 05:29 PM
Bandit74
15
Sep 17, 2004 09:36 PM
SuicideSlide
Sep 5, 2004 03:44 PM
bigD
Sep 21, 2001 12:52 AM
