Heavy Duty... Exhaust Manifold Studs?
Does ARP make them for hondas? Between my precision turbo and clunky heavy *** ramhorn manifold, the studs break within 2 or 3 hard pulls on the street one by one. Getting sick of the exhaust manifold leaks, any suggestions? This is for a b16 btw.
hum... interesting.
I've never heard of people having to upgrade exhaust manifold head studs due to weight or flex of motor...
added to my 500whp WTB build list
the setup...
sometimes you have to upgrade the studs due to a really thick manifold flange. its def not a bad idea and the arp hardware is really nice but def not cheap.
good point:D it's sum custom made ramhorn I got from a friend, it's made out of schedule 40 though so it pretty damn thick and heavy. I was looking at the ARP stud kit and I dunno how I am gonna tighten down those 12 point nuts. I can only fit a open ended wrench around the manifold as we speak and even that's a PITA.
its more like would you rather pay $100 on upgraded arp studs or $35 a hole to the machine shop to fix each broken stud in your head. if you keep an eye on your motor at all its not like the turbo manifold and turbo are going to disappear...
If you want to cheap out on something that I would consider insurance, that's totally up to you. I would rather have the peace of mind knowing that my turbo and manifold are nice and secure, especially going down the track at 100+mph. To each their own.
sounds like you like to spend alot on your cars. never once did I say it was a bad idea or dumb to do, its just pricey. my stock exhaust manifold studs work just fine for what I have but I had a buddy who had to go with longer studs and we just went down to the cascade nut and bolt store and paid $12 for what we needed, holds up his top mount and 62/62 just fine
Do you hit the 2-step a lot? I know I used to shear a lot of studs when I went nuts on the 2-step on a few occasions.
Those ARP manifold studs are friggin expensive...
I solved the problem by going with bigger 10mm studs. The few times the stud broke, the four outer studs were seized inside the cyl head, so I had to drill them out. At the same time, I drilled it out to a 10mm stud size and tapped it for a 10mm x 1.25 thread. I had to enlarge the holes for the manifold, and that was it. 4x 10mm studs prevented all studs from ever breaking again.
You're going to be hard-pressed to fit the studs with a ramhorn, the ARP kit is great, we use them all the time, but without seeing the clearance you have from runner to flange, I'd say you're best off bracing the turbo and manifold by the flange at the collector.
I will get some pics up Monday of the clearance from the runner to flange, i'm very hard pressed for room now.
