which f23 rods
Old Dec 22, 2010 | 08:03 PM
f20b jones's Avatar
Default which f23 rods
i finaly got everything for my new build but rods. Im running a f23 crank and f23 rods . its a all motor set up but i plan on making close to 300hp and i have alot of good stuff in this build so i dont want to chance stock rods. I can order a set of crower but there 760 dolars . I dont realy want to spend that much and im sure there has to be somebody else out there that makes a after market rod for a f23 crank that would be fine for a all motor set up. Basically im just cheap and looking for a cheaper f23 rod any help would be nice thanks.
Old Dec 22, 2010 | 08:24 PM
m_shake's Avatar
Default Re: which f23 rods
Haha had to edit after rereading you post, I think crower may be the only OTS option... How high you planning to rev this? Big stroke=big piston speed
Old Dec 22, 2010 | 08:30 PM
cibao2ner's Avatar
i have a set of crowers for the f23...for sale
Old Dec 22, 2010 | 08:34 PM
m_shake's Avatar
haha there's his answer...buy em!
Old Dec 23, 2010 | 12:00 AM
gstrudler's Avatar
I looked around as well and couldn't find anything other than crowers. For budget reasons I stuck with the OEM rods; plenty of G23's out there running just fine without broken rods.
Old Dec 23, 2010 | 07:35 AM
Bisimoto's Avatar
Maybe the time has come for us to make some cost effective ones. If interested, feel free to write to sales@bisimoto.com
Old Dec 23, 2010 | 07:39 AM
SP GARAGE's Avatar
Finally someone stepping up to make us some rods
Old Dec 23, 2010 | 02:28 PM
cibao2ner's Avatar
i have a set of crowers for sale..and i also got an f23 long block....will that make a decent allmotor set up with the h22 head? i might keep it...i was going to boost an accord but changed plans and sold the car...what other engine can i use 86mm cp piston? can i use f23 crank rods and pistons on a h22?? is the h22 bore 86 or 87mm cant remenber..
also if i got turbo on the f23 can i fit the older f22 heads...the one bisimoto uses on his allmotors builds...
Old Dec 23, 2010 | 07:29 PM
f20b jones's Avatar
h22 is 87mm but i do have a perfect f20b block that comes with steal 86mm sleeves stock. That would be your best bet get a f20b block it already has steal sleeves and h22 head blots up with no jb welding or any bull ****. If i didnt have two sleeved blocks i would build it myself. Text me at 478-808-9122 if you have a set of f23 rods for sale thinks . I have probably three f23 bottom ends so i dont need stock rods lol .
When i pmed you back i didnt realize your pistons were 86mm i might go ahead and get both just text me.
Old Dec 23, 2010 | 07:31 PM
f20b jones's Avatar
I have actually talked to a few custom rod makers that say they can make the rod for around 250.00 . I just dont want to take a chance being the first person to use a set lol
Old Dec 23, 2010 | 07:39 PM
Madmood's Avatar
If they make rods for a living. What chances are you taking? Get over it and do it. You honestly wont be the "First person" to have these rods made for...
Old Dec 23, 2010 | 08:21 PM
Professor15's Avatar
How much are aluminum rods going for nowadays? Might want to look into that aswell
Old Dec 23, 2010 | 09:12 PM
f20b jones's Avatar
Im sure i wouldnt be the first but i didnt get these names off here or any were reliable if i did they would be made already. Im trying to work a deal with the guy with the crowers now and im going to build to botttom ends so i might try some different ones in the second bottom end.
TravisBiggie
Jul 5, 2012 03:43 PM
Gatweb
Feb 6, 2006 07:11 PM
1BADGS-R
Dec 30, 2003 07:08 PM
Soon_2b_evil
Jul 13, 2003 07:51 AM
teg92
Sep 6, 2002 08:53 PM
