fuel pressure regulator vac for bov???
Old Dec 22, 2010 | 04:43 PM
bubskie's Avatar
Default fuel pressure regulator vac for bov???
Hi guys, im trying to tap a vac to my bov, and i was wondering if it is possible to use the source from the fuel pressure regulator. Thanks guys.
Old Jan 2, 2011 | 09:31 PM
bubskie's Avatar
Default Re: fuel pressure regulator vac for bov???
^^Bump^^
Old Jan 3, 2011 | 04:50 AM
TheShodan's Avatar
Moderator
You another dedicated source on the intake manifold. That's a better source for vacuum than the FPR line.
Old Jan 3, 2011 | 01:45 PM
JDM B20 EH2's Avatar
I was wonderin about hookin my boost gauge there. Everyone I talked to recommended me to use a diff source and don't T into that line. For my bov I used the nipple runnin from the nipple the used to run to my evap canister
Old Jan 13, 2011 | 01:44 AM
bubskie's Avatar
I tried running my boost gauge there but it wasn't reading. I was using the nylon line. I'm going to try to use a rubber one tomorrow. That source isn't a good vac. For bov- bov not too responsive. I've read that some ppl has ran the gauge there and it works. Hope that helps.
update: Fuel pressure vac is fine for boost gauge source. I'm not sure if it is too effective for bov though.
boostinh2x
Oct 2, 2011 11:00 AM
Mr.Death
May 3, 2006 06:49 AM
Egg-weezy
Mar 31, 2004 08:23 AM
_Endless_
Nov 18, 2003 10:32 PM
Vtec92Civic
Aug 26, 2003 01:26 PM
