Help need, try to build own b-series simulator
Hi all, i like to build own b-series engine simulator, but to follow in pgmfi it to advance for me.. I need to understand how all device function.
P30 input device :
RPM (Tach signal) - There component can convert voltage to frequency!
02 sensor - Are this sensor send voltage signal to ecu?
MAP sensor - Are this sensor send voltage signal to ecu?
Manifold Pressure - Are this sensor send voltage signal to ecu?
Throttle position - Are this sensor send voltage signal to ecu?
Intake temperature - Are this sensor send voltage signal to ecu?
Coolant temperature - Are this sensor send voltage signal to ecu?
Output :
Injector
Vtec solenoid valve
*Can simulate by using LED
it same like moates.net B-series sim board. but love it if can build this own hand
P30 input device :
Output :
Injector
Vtec solenoid valve
Get yourself a multi-meter and a scope and start figuring it out. That's what building it yourself is about...
Or just get one from here and save yourself some time:
http://www.moates.net/honda-b-series....html?cPath=69
Related part : CKP, CYP, TDC + Distributor. (In progress circuit and fit component)
http://easyautodiagnostics.com/honda..._systems_6.php
Just thinking to order pocket oscilloscope from ebay.
http://cgi.ebay.com/2Msps-Sampling-R...item2c58aeacab
but dont have any idea how accurate this device since it made from CHINA
StraightCivic
10
Apr 5, 2006 12:27 PM
otakueric
Sep 13, 2005 04:49 PM
