Car dies after warming up
Old Dec 20, 2010 | 05:54 AM
JAGCB7's Avatar
Default Car dies after warming up
Hello,
I have a 1992 Accord, after warming up or driving about 10 miles my car will start to feel like its mis firing. It will then die and not restart till it becomes cold again.
I replaced the igniter inside the dizzy but it still does it. Also replaced the Temp switch.
Another sympton i have is that when i first start it the idle will continually jump between 1000-1500 until it fully warms up.
I went ahead and posted this while i am searching on here for similar problems, any input would be helpful. This car also has zero mods, its my daily!!
Old Dec 20, 2010 | 06:02 AM
MONEY888's Avatar
Default Re: Car dies after warming up
Hey wuts up have youve done a compression test if u havent try doing one it might be your valves are not seating right .
Old Dec 20, 2010 | 06:04 AM
MONEY888's Avatar
or you might have a slightly blown head gasket and maybe there is coolant entering the cylinder causing your engine too die out .Do a compression test look at the plugs also .
Old Dec 20, 2010 | 06:21 AM
JAGCB7's Avatar
Ok, Ill pull the plugs today and look, any other problems that could cause this?
I checked the Oil, its not a milky color. This would mean that I do not have a blown head gasket correct?
Old Dec 21, 2010 | 12:39 AM
madmattr6's Avatar
Yes milky mine looked like light colored coffee
Old Dec 21, 2010 | 04:24 AM
JAGCB7's Avatar
Ok well i replaced the disty which was 167$ still didnt fix the problem. Going to clean it up and return it. Ill try the main relay next.
Old Dec 21, 2010 | 08:43 AM
hondamark35's Avatar
doesn't sound like a main relay. sounds like the catalytic converter is clogged.
it's not terribly difficult to check (but it may be loud!). remove the converter from the rest of the exhaust system and look inside to see if things appear to have melted and or clogged.
mine looked like this...
if it looks something like that you'll probably need a replacement. you can confirm that this is the root cause by letting the car warm up with the cat off, then driving it to see if the symptoms persist. this will be the loud part.
Old Dec 21, 2010 | 12:22 PM
JAGCB7's Avatar
When I took the disty off my car I removed the cap, It was night time while doing this, and something metal fell off after i took the rotor off, anyone know what it was? I googled a disassembly of our distys and found nothing that would have fallen out.
Old Dec 21, 2010 | 12:31 PM
frankens_tein's Avatar
u will need a lot of money
Old Dec 21, 2010 | 01:13 PM
SkRiBLaH's Avatar
aint that the truth
Old Dec 21, 2010 | 01:24 PM
JAGCB7's Avatar
What does this have to do with fixing my car?
Mmd
May 30, 2017 12:54 PM
EM1Guru
24
Jun 27, 2012 09:29 PM
kreatekustomz
Jul 3, 2010 04:17 PM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
schwett
Mar 24, 2002 09:39 PM
