Head help
Old Dec 16, 2010 | 11:54 PM
Maddvtec's Avatar
Default Head help
i took my header off to get them patched up and i found some oil in the exhaust chamber pull the spark plug and there's no oil spot anyone have any idea what this could be i was leaning toward valve seals but i am not sure anyone know???
Old Dec 17, 2010 | 05:20 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Head help
valve seal. How much mileage is on that head? If the valve to guide clearance is out of spec from wear, changing the valve seals will only solve the problem for a short time before it starts leaking again.
Old Dec 17, 2010 | 08:53 AM
b20vtech's Avatar
about 60-70 percent of my customers heads needs new guides when they come in for portwork and valve job. You should really consider taking your head to a local machine shop and have the valve to guide clearence check out.
dominate9
Apr 14, 2020 02:10 PM
80 dolla crx hf
Sep 8, 2014 01:28 PM
Atomic1
Mar 27, 2010 08:57 PM
DS_Vtec
Oct 14, 2007 11:36 AM
SYN4DRDX
Jul 9, 2005 12:09 PM
