Need help with road course build
Old Dec 16, 2010 | 04:42 PM
V/\ freestyle's Avatar
Default Need help with road course build
Im trying to think of the best way to put power down threw a jdm d15 and a si l3 tansmission.. I have a ef etreamly gutted with a fuel cell. should i turbo or go n/a .. how much power should i shoot for? If i where to turbo what would be a solid setup to keep me going around the track with traction a reliably.
all set up info and experiance info would be helpful
Old Dec 16, 2010 | 05:13 PM
d15b7inEF's Avatar
Default Re: Need help with road course build
Are you working with a stock block or is it sleeved and are you running a stock head
Old Dec 16, 2010 | 05:31 PM
Zajnet's Avatar
It depends on what you like, but all it takes N/A to win the class is around 190whp and a good driver. A JDM D15B can do that all day with a high comp build with some .025 over pms pistons.
Old Dec 16, 2010 | 05:53 PM
[QUOTE=d15b7inEF;44240797]Are you working with a stock block or is it sleeved and are you running a stock head[/QUOTE
completly stock internals.
I wouldnt really want to do a lot of work if i was going to boost it anyways.
would a stock d15b be alright for racing like that?
Old Dec 16, 2010 | 05:55 PM
So for around a d15 class i should make 190? thats more money then i wanted to spend. thats why i kinda just wanted a cheap/solid turbo setup
Old Dec 16, 2010 | 09:08 PM
FSRslug's Avatar
Starting in march, I will be running a stock D16Z6 with a T25, 4-5psi. Shooting for about 150hp. With a car that is under 2000lbs, it shoudl be pretty fun. I had a stock D15B2 in the car before and it was fun, but slow. On the longest straight, we topped out at about 100 and it didn't pull hard out of the corners, so momentum was key to going fast. I would have boosted the B2, but it was only making 120psi on all cylinders after the first race, so I scrapped that idea.
Traction is going to depend a lot on your tires and how you drive.
Do you have class restrictions for what you are doing with it?
Old Dec 17, 2010 | 08:13 AM
Zajnet's Avatar
Well, you wouldn't need to make 190 to have a lot of fun. The national winner of the Street Modified FWD (SMF) class usually has around 190-200hp, but to have some fun and maybe win your region about 150 should do if you can drive. A jdm d15b can do that on stock internals with just bolt ons and a tune.
You'll also need to spend a decent amount on tires. Hoosier road racing slicks are the way to go unless you're shooting for a class that doesn't allow for them, but SMF does.
Old Dec 21, 2010 | 08:06 PM
thanks. bunch of great info.. keep it comingg
Dugdude
Aug 25, 2013 11:43 PM
ef71510
Aug 4, 2011 08:13 AM
Jake92eg
Mar 31, 2006 10:56 AM
integlspwr2k
10
Mar 13, 2006 11:05 PM
superturboprelude
Dec 13, 2005 05:23 AM
